Question about Car Audio & Video
I was pulling my car radio & think i might have disconnected it. how can i fix it?
    Scholar:
  • 71 Answers
Check your fuses. Wiring is like plumbing.  Follow the feed.  Need a lot more information but just plug it back in if it's a harness.  It's it's just spliced together then you have to check each wire by disconnecting and rewiring properly.  Rewire while car is off turning to Acc after each wire.  Start with power, ground, pow ant, to verify connectivity.  Once power is on start with speaker wires.
Posted on Sep 09, 2008
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
Dec 03, 2013 | 2006 Chevrolet Malibu
I HAVE A 2004 INIFINTI, WITH 52,000 MILES ON IT. I HAVE PURCHASED 2 BATTERIES FROM AUTOZONE IN THE LAST 2 YEARS. IF I DON'T DRIVE FOR 3 DAYS, CAR WILL NOT START. IS IT THE BATTERY? DO I NEED TO PURCHASE...
Sounds like you have something pulling the battery down. Is the radio still factory? If not my first suspect is an after market radio. If all is still factory, no radio, no alarm system, no back seat chargers, dvd players. Your alternator may be the cause, alternators have diodes that can cause a "leak" or a small draw on the battery. If you have a volt/amp meter you may be able find this. If not take the car to auto parts store where they can remove the positive cable and read the amp pull, in between the battery post and the cable end. You will have a very small amount due to the radio clock. but if your reading is in the 1 - 3 amps that is too much and causing the batt. to go dead after 3 days. Disconnect the largest wire on the alt. and read the amps again, if it has gone down and reads normal, that is the alternator diodes leaking, and shes bad. Hope this fixya up.
Nov 21, 2010 | 2004 Infiniti FX35
Radio quit working when I hooked up a portable compressor lighter
The radio uses a five amp fuse, maybe 7.5 amp. pull them and look at them you tell they are blown
Jun 17, 2010 | 1995 Chrysler Town & Country
Have a short or something draining battery. alt is fine battery is new. Noticed clock is on all the time. Will not turn off with key like radio. Will the clock drain a battery dry in as short as a week of...
Get a multimeter then disconnect the positive side of the battery. Measure the amp(current) between the terminal you just disconnected and the positive battery while the car is off. and have someone get a tweezer and pull out one at a time each fuse in the fuse box. When the amp goes down on the multimeter then you found out where in your car there is a short. Note the fuse you pulled out in your car manual. It could be radio shorting, domelight shorting. Sometimes kids drop pennys or coins in the radio disk slots shorting the radio or amplifier in the car is always on.
Mar 27, 2010 | 1994 Oldsmobile Cutlass Ciera
Radio not accepting manufactur code.
If it is the correct code, you may have entered it a few times & locked the system. Either disconnect the battery & wait a minute & reconnect & retry, or pull the radio fuse & retry after waiting a minute & reinstalling.
Feb 14, 2010 | 2003 Honda Odyssey
My amps wont turn on but it was just fine yesterday
check the amp. fuse, if this is OK with the radio On check the turn on wire at the amplifier must have voltage if not, check if this wire has voltage at the radio if there is voltage, the wire is broken some where.
Jan 07, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I hooked up my Pioneer DVD-5000 to my Amp and all I did was hook up the Remote Wire to the Amp and when I turned on my care my deck doesn't light up or work any more? Did I fry my deck? Can I fix it? What...
sounds like a connection is wrong and if it shorted it prob blew the fuse for the radio. Disconnect the radio from the amp then pull the connecter out of the radio and check the ten amp fuse...
Jul 24, 2009 | Car Audio & Video
2003 toyota corolla radio A51802
It sounds to me like a resistor is fried in the radio. You could buy an after market stereo or the one on ebay, it's your choice as to which route you go. It would cost you more money to fix this problem that to just buy the one on ebay. If it comes with a legit. warranty, then it's definetly worth it. I hope this solution helped. Please rate. Thanks.
Sep 28, 2008 | 2003 Toyota Corolla
Car Audio & Video Logo
60 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
