Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Red Vertical Burn Line on LCD Screen
We have a Motorola Cable Box (supplied by Shaw Cable), and on our Non-True HD Channels a border appears on each side of our Screen (happens to all customers using the Motorola Cable Box). The borders have created a red vertical burn line on our screen. A technician told us that the only way to avoid this from happening in the future is to change our picture setting each time we view a Non-True HD Channel (which is a pain in the ****). If we put our picture setting at 'full screen' it will not hold because the Motorola Cable Box reverts it back once we switch channels. Thank gawd we have a 3 year extended warranty and will receive a replacement/new television. Do you know of any way we can permanently set our television to hold a 'full screen' picture setting which won't be reverted back due to the Motorola Cable Box? Also, do you know what the cost of a replacement flat panel screen is? The technician figured it was around $800.00 Canadian.
  • tomcatz Sep 09, 2008
    www.fixya.com/users/stevediraddo: We change the picture setting through our TV remote, not through our cable box remote.
  • 22 Answers
Try changing the picture setting on the television rather than from the picture box.
Posted on Sep 09, 2008
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Green screen when HD channels on FIOS is on, but normal picture when non HD channels are on
unplug your cable box and your hdmi cable from the back of cable box and reboot it..its the cable box not the tv..I'm just a mom ..sometimes we think outside of the box ..no pun intended!!!
Nov 22, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Just want to know if i can get hd channels with a regular comcast motorola dct700 box, if so how? Also, what DVD player should I buy with this, as well as type of cables. TV just given to me, no remote,...
No HD channels on a DCT700, you have to have a HD capable box from comcast. Usually $8.95 a month for box rental. Don't know a lot about DVD players. If you get a comcast HD box, and have an HD TV, you should use an HDMI cable for best picture. Second choice is component cables. Those are the red, white and yellow or red, white yellow, blue and green cables.
Jan 03, 2010 | Haier HLH32ATBB 32 in. LCD HDTV
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Jun 28, 2009 | RCA L32WD22 32 in. LCD HDTV
Non HD channels pixellating...sort of....
i have the same box and notice the same problems it is just becaus anolog siginals are crappy and the way the box converts the things causes the problem. nothing can be done. :(
Jan 22, 2009 | Arris DCT6200 DTV Receiver
Green Line in Philips 42TA648BX/37 42" LCD
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Jan 15, 2009 | Televison & Video
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Vertival Color Lines
We had the same thing happen to us on the right-hand side. A technician told us yesterday that the Motorola Cable Box (supplied by Shaw Cable) places a border on Non-True HD Channels. Because we didn't place our picture setting to 'full-screen' each time we viewed these channels and burn line was created. He gestimated a replacement screen runs about $800.00 Canadian, but we have a 3 year extended warranty and will receive a new TV. He also said it happens on all big screen tv's that use a cable box creating borders on Non-True HD Channels.
May 04, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Gray borders on the HD channels
Have you tried to change the screen size? To do that press the "Psize" button on the remote till you find what you need.
Dec 29, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
299 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
