Question about Intertherm Heating & Cooling
T-stat problem I am workig on a 92 intertherm.Trying to install new stat to control heat and cooling. top of control panel only has C Y W R were does the fan wire (green) connect ? the only #s I have togo by are 901698-2wire relay box
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
HEY, the only logical explanation is, that unit didn't have fan only.
Posted on Sep 09, 2008
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
I have a carrier 38YC(M) heat pump and trying to install a programmable t stat (honeywell RTH6350D). One of the setup steps asks what kind of pump it is: with out without backup or auxillary heating,...
"Two" of the most complicated items that "experienced" Air Conditioning ServicePeople deal with are (1) Control voltage for Heat Pumps and (2) Installing a Programable T-Stat.
My best advice to you would be to find an experienced ServicePerson to wire the T-stat for you. I can assure you that you will save time and possibly money by doing so.
Jun 12, 2011 | GE Heating & Cooling
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
Installed new stat and fan won't come on in heat made or cool mode.
Turn the thermostat switch that says fan on------auto to on an see if the fan comes on ,if don,t then the problem was the circuit board or find power wires going to the fan motor and jump it out to see if the fan motor is good or bad. then if it starts, then you,ve know ,you,ve eleminated the fan motor and its the circuit board...
Dec 08, 2009 | Intertherm P3RA-024K Air Conditioner
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
Thermostat wiring diagram for heat and cool unit
out door unit staying on disconnect the yellow wire for compressor if still on contactor bad points whare main line voltage is connected if unit goes off stat bad also check for weedeater damage to stat line at unit hope this helps most systems green fan yellow compressor blue common orange reversing valve white aux heat strip remove stat cover to see how unit is wired up
Jul 03, 2009 | Heating & Cooling
I have 2 seperate controls ,1 for heat the old honeywell round turn styls and then i bought a new digital thermostat ritetemp and i have 3 wires for the airconditioner white,red and green, i just cant...
on the round its r g w hook that on the new stat if your using it for heat to then the rh and w are heat controlling baseboard or a boiler relay? the new stat has a jumper wire remove that it is hooked up to rh and rc un plug every thing good luck Tom
Jul 03, 2009 | Intertherm P3RA-048K Air Conditioner
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
look on indoor unit to see what they used if only ac unit then only 2 wires needed common usually blue or black and yellow if heat pump then orange for rev valve o term on stat r red y yellow then white or brown for call for elect heat in defrost and blue or black for common also take some 3/8 clear tube to incase the stat wire and zip tie it to top of line set to help stop this
May 07, 2009 | Intertherm P3RA-030K Air Conditioner
A contractor cut the wires from my Coleman forced air furnace, It was hooked up to a stat that ran my evap cooler and heat. I am trying to put in a new straight heat stat but I can't get the stat to...
Does the new stat have a pin labled (G)? Connect your fan wire (usually green) to that pin, and then call for fan on your therm. Straight heat stat means it has only heat and cool pins, there is no option for fan. If your not getting the fan to come on including heat, make sure you have the white wire and red wire connecting to your new stat.
Dec 06, 2008 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
