Question about GE 24 in. GSD500X Built-in Dishwasher
Broken Door Spring
My dishwahser door was open and I heard a snap. When I lifted it, the door was very heavy so I assumed the spring must have broken. A few days later the door fell all the way from closed to open position, and now it's not only heavy, but feels like it is scraping when you close it. How do you replace the springs or do you need a technician?
  • 1 more comment
  • Anonymous Nov 10, 2007
    I need to know how to attach the cables and spring to the door.
  • Anonymous Mar 22, 2014
    The spring that holds the helps the door open and close is not working or is broken
    broken spring on door making it heavier to lift and drops hard
    Champion:
  • 277 Answers
Hi you can do it if you have good hands open the cover side of the broken arm with the spirngs understand how the Mechanism works (in\out) and what went worng and hopefuly fix it or replace the springs that died good luck
Posted on Mar 26, 2006
SOURCE:
Fix broken garage door torsion spring
I would call a residential door company. Those springs are not something I would recommend the average homeowner to mess with. Sorry!
Jun 01, 2015 | Building Materials
My garage door will not open. I pulled on the emergency rope to see if that would help but it did not.
Your torsion spring is probably broken. After you pull on the emergency rope, press the remote, that should move the chain and emergency lock out of the way, then you and 1 or 2 other people may be able to lift the door up if you really need to get the vehicle out. It depends if it is a single or double door or wood or metal, how heavy it will be. This can be dangerous and it could fall down on you. Check your torsion spring above the top of the door when closed, if there are two pieces then it is broken (on a single door.) A double door will have two springs, one on each side. One may be broken. You will need to get all the springs replaced, it counterbalances the door. If you have a garage door with arms on it, then the compression/extension spring is probably broken. If you are mechanically inclined, you can replace them, it is dangerous, be sure to watch a UTUBE video on it.
Dec 21, 2014 | Building Materials
The auto-closure spring for the door appears to be broken. What is the best way to go about repairing it?
You need a new top hinge, call true at +1 800 325 6152 for part numbers and ordering info. They are very secretive about their info, they may or may not help. They may refer you to a local tech company. I can get the parts if you can't get anywhere with them.
Feb 11, 2013 | True GDM-26 Refrigerator
The dishwasher door spring has snapped, the door is heavy, can I fix it myself?
Yes, you can repair the unit yourself. It will require removing the dishwasher out of the cabinetry to get to the spring cable. The spring is not the problem but the connector between the door hinge and the spring is broken.
The part you need is 4933DD3001B. You will need 2 of them.
Hope this helps.
Oct 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
Garage door does not open. goes up about 4 inches. disconnected from opener and still can't open. checked wheels in frame move by hand. opener works when not attached to door.
You probably have a broken torsion spring. If you have a spring on a shaft above the door (usually 2 if it is a double door) then you have a torsion spring. From this shaft you have a 2 cables wound on a drum going down to the bottom of the door. If it is a single door, then this cable will be loose. If you have a double door, then most likely one spring is broken. This allows the door to open slightly, until one side is trying to lift(good spring) and the other side cannot (broken spring) Unless you are an EXTREMELY CONFIDENT DIYer then you should leave this do a door repairman as winding a torsion spring is dangerous, and can break bones or even kill. Now if your door has extension springs on each side of the track,with a pully and cable, then these can easily be replaced yourself. Check that cables are connected to the springs and the door and that one didn't break or come loose or cable off pully and binding.
Oct 21, 2010 | Garden
Chamberline 1/2 hp belt drive opener that stops opening
It sure sounds like a broken spring. Sometimes the break can be difficult to see. How heavy is the door to lift manually. This will give you a good idea.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dishwashers Logo
781 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
