Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Reboots every 30 seconds or so
Don't understand this. BIOS set to fault. Even with a freshly formatted HD and Windows XP CD in place the board reboots after about 30 seconds. Help!
  • barramundi Nov 24, 2008
    Turned out that replacing the power unit made the problem go away!
    Thanks for your ideas guys.
  • Daniel Jenkins
    Daniel Jenkins May 11, 2010
    Could be faulty RAM, replace your ram and see what happens
    Problem Solver:
  • 7 Answers
Hi, there is your CPU a 1400mhz athlon (NOT athlon xp) or lower?, it just so happens that i have the same motherboard, and i tried an AMD athlon 1200mhz on it and when you go to install windows xp, or try to boot windows up it just reboots, like it doesn't like you!, well if you are in the same boat, which i think you are then you need to immediately remove the cpu and stop playing with it, because the 1200mhz i had on it fried itself after about 20 tries!, But There is a solution, an amd athlon xp 1800+ works just peachy so anything above or maybe slightly lower will work!, currently on Trademe there is a number of amd athlon 1800+ cpus for sale, follow this link, # http://www.trademe.co.nz/Computers/Components/CPUs/AMD/auction-182065118.htm# excluding the hashes, i hope this helps.
Posted on Oct 14, 2008
  • 781 Answers
Check all your fans and heat sinks including power supply one
Also check CPU heat sink for fluff and dirt
Posted on Sep 09, 2008
ASUS EeePc 1015PEM reboots at windows startup. even with new hdd and fresh install. ok when in bios screen or if i boot into linyx
Which windows OS are you using? windows xp, 7 or 8?
Anyway the problem might be corrupted installation CD. If you install windows on other computer using this CD, so if CD is OK, then
start your laptop and press F8 repeatedly until Windows Advanced Boot Options appears. Then choose automatic restart on system failure. This option will allow you to see Blue Screen Of Death and to understand what causes a problem.
Sep 21, 2013 | ASUS - EEEPC Eee PC 1015pem-pu17-wt...
How to reboot a XP4 computer
1 first insert the windows cd in cd/dvd rom 2 chek in the bios if the first boot device is the cd/dvd rom 3 vhen it boots it will say press any key to boot from cd 4 after loading all the data you must format drive C 5 after formating it will restart instaling windows you must insert the windows cd key thats all
May 16, 2011 | Microsoft Windows XP Professional
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
OK, in a nut shell -- Cant get XP to start. Computer ONLY reboots and reboots. Want to ERASE hard drive and start over OR SELL COMPUTER after erase. HOW CAN I ERASE HD -- HOW DO I GET TO ...
you need an XP CD.
insert the disk to the CD/DVD drive and boot from CD
you can change the boot sequence in bios or press F12
when it says press any key to boot from CD rom
press anything on your kybd
and let the windows to load
it will ask you if you want to repair or install windows press enter
then press F8 to accept the EULA
then press ESC to install a fresh copy of windows
you can delete the partition by highlighting the drive that says
C:\Windows then press D to delete then Press L to confirm
and follow the onscreen instruction
hope this help
Sep 07, 2010 | Computers & Internet
Hi!, I'm trying to install a brand new WD 500 Gb HD on a Dell Optiplex GX260. The problem is that even though I can see the HD on the BIOS Setup I can't get pass the Message... Press F1 for help or F2 (For...
boot to BIOS
turn on caps lock, scroll lock and number lock,
Press ALT+E (Should get a Single Beep) Press ALT+F (Another Beep) Press ALT+B (Reboot)
Make sure you have Windows CD in Optical drive and once it reboots it should start the OS load
If you don't have the most current BIOS, you may need to install old HDD, Download and install latest BIOS then repeat steps above.
Sep 02, 2010 | Western Digital 500GB My Book Pro-External...
My AMD computer started rebooting on its own minutes into a boot. I tried reinstalling a fresh copy of XP but it would reboot into the installation. It reboots in the BIOS setup so it is not the O/S. It...
this is a mobo setting try reseting the board using the bios jumper switch it to the reset possition turn on pc /switch off pc and replace to original setting see if this helps b4 replacing board
Jan 01, 2010 | Computers & Internet
How do i erase windows 95 and replace it with windows 98?
you get a copy of windows 98, pop in the disc, click upgrade (or fresh install if you don't wanna keep anything), and let her install. About 45 minutes after it reboots you should check on it because it has a dialog box for you then.
Sep 27, 2009 | R.A.M. Computers Featron FT6750, Pentium...
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
NO BOOT OPTIONS FROM CD
simple if you need to format your system then insert the windows xp cd in a normal mode and go to installation and it will ask for the an upgrade or fresh installation select fresh installation no need to enter bios this reboots your system via cd and let youformat your machine.
Feb 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Got a question for you...
The windows XP pro cd has the tools you need
DO NOT FLASH THE BIOS
DO NOT ERASE THE HARD DRIVE
sometimes when the hard drives are erased and they are SATA the bios won't recognize a RAW SATA drive.
  1. enter the setup utility and configure the BIOS Boot order to boot from CD/DVD
  2. insert Win XPPRO CD
  3. apply settings and save and exit
  4. reboots automatically
  5. press any key when prompted
  6. select the install
  7. select the primary partition you want and delete that partition.
  8. confirm you want to delete it,
  9. quick format to ntfs.
  10. once formated the loading of the OS is auto
Apr 19, 2008 | Computers & Internet
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
142 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
