Question about Sony STR-DE845 Receiver
Sound cuts off
Hi! My receiver plays audio fine for about 45 minutes, then starts to lose the sound, i hear a click, and all audio stops. I press on the display screen or on the side, move the receiver somehow, and the sound clicks on again...this keeps getting worse and worse though...is there a fix, or am i doomed to dish out money for another one?
  • ItaliaFreak Nov 07, 2007
    Same issue. Try pushing the A&B selector switch to one side or the other. This worked for me for the past year now. Got tried of it cutting out and doing it again so I turned the reciever on its side. Only the back surrounds cut in and out and now nothing at the backs. Maybe 5 years old now.
    Problem Solver:
  • 5 Answers
He's partially right... I have fixed 3 shorts on my de845. 2 have been caused by cracked solder joints. they were speaker cutout problems...yours most likely is the center channel relay on the main board. take the thing apart. you need to get to the back of the main board and re-flo those solder joints. get your geeky pc buddy and do it together(buy him a sixer). its really not that hard...just a bunch of screws. disconnect everything from the main board including the front plate. be careful with the ribbon cable...mine is hurting at this point. not meant to be removed so many times. put it in straight. my leads bent, but was able to straighten them. there are 5 relays together, one for each channel. they are white cubes and prb a little smaller than the tip of your finger. its the 4 leads on each of these that you want to take a soldering iron to . i'm not sure which ones the center channel so do them all in that area. it may be hard for you to tell which leads they are so just go overboard and at least get everything in the vacinity. i did all component leads because who's to say another's not ready to go bad. you've gone this far. touch the heated up tip to all the leads at the very end of the barb. you can reflow the solder without actually touching it. the metal lead will get hot enough. hold it until the solder liquifies, then let it cool. do this on a flat surface. my other fix once was a re-seating at the speaker switch a,b,a+b on the front plate. there are 2 boards plugged together there. i bent the leads slightly so they seated in more tightly. if your left or right front goes out, sometimes thats an easy fix...try b if you're using a, or the opposite. don't forget the speaker cables. if you're using both zones then you prb already figured out you need to re-flo! test and cross your fingers. good luck.
Posted on Jul 27, 2007
Unit power stays on (display and lights) but no sound, no protection message on display. Remove cover and then 8 screws on front panel. The power switch board and main display board has a 4 pin connector between them. Reflow solder on both boards, reconnect everything and it will work forever!!!
Posted on Sep 27, 2007
    Champion:
  • 277 Answers
Hi sounds like a heating problem probebly the heatsink of the AMP is cloged with dust unplug from wall open cover vacuum all the dust and then clean well place the reciver on top of all the components for a good ventilation good luck
Posted on Mar 26, 2006
I have a jvc kd-r440 radio installed in a 2001 stratus rt. It will play fine for a bout 10 mins or so then loses sound. If you push buttons you can hear beeps through the speakers. But no music. Tried to...
You need a new radio. Amp in the radio is bad. When you first cut on the car its cool. After 10 minutes it gets too hot to operate so it cuts off.
Oct 21, 2014 | Car Audio & Video
Delayed Sound from Center Speaker
Go to this website, make an account, go to support, help center. Thenfollow the instructions and you might get your answer.
Hope this helps. :)
Jan 21, 2008 | NAD T762 Receiver
I recently hooked up my pioneer cd player in my car and when i play a cd it works fine for awhile but then the sound goes out. i double checked the wiring and the battery and its all connected right. the...
Hi:) Sound like the pre-amplifier transistors are burnt out if you hear no sound at all. If you can hear a very fate sound then it would be the Output amplifier IC's. If you are using a separate output amp check the amp.
Mar 16, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
After a few minutes of playing a cd or the radio, the speakers make a thumping/crackle noise and the music stops. The stereo stays on. Just stops playing music. Any ideas?
Hello
OK, this is just a suggestion, without analysing the unit myself.
From my experience with these type of units, it is usually overheating of the IC's on the circuit board.
You can do another test just to double check. Turn the unit off, unplug it from the wall supply for about 10 minutes. Then plug the unit back in and turn it on. Now turn the volume very high, without the speakers starting to distorted, where you can still hear a clear sound.
Now, if this is an IC overheating, the sound should start distorting and cutting out. This is actually a very common occurrence with these types of players as well as receivers in general.
Try the above, let me know what happens.
Also, please do not hesitate to let me know if you need any further assistance.
Kind regards
Andrea
Nov 10, 2010 | Panasonic SC-PM41 Shelf System
I have a Denon AVR-587. It has worked fine for 2-3 years, but ever since I tried to connect it to a different set of speakers, it cuts out after a few minutes and I hear this loud clicking sound coming...
There is a short either on the speaker wires to the speakers or the speakers are defective (some sort of a short or too low of resistance). Lastly, check to see if a stray strand of wire is not touch the left and right terminals. Any short in the network (wire, lack of insulation, staple, screw, etc. ) will cause the system to clip.
Nov 10, 2010 | Denon AVR-587
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
No sound for *some* blu ray discs / can't get a menu
Some blu ray disc play fine. Others play the menu music, but when the feature starts, the sound disappears completely. And then others don't play music at all, no sound what do ever.
Feb 05, 2009 | Onkyo TX-DS838 Receiver
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Nov 28, 2008 | Sony STR-D665 Receiver
Popping noise and loss of sound
Check the preamp Coupling Capacitor, which might have lost its value, or might have leaky dielectric.
Feb 24, 2008 | Pioneer VSX-D409
Sony STR-DE845 Receiver Logo
263 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
