Question about Sanyo DS27910 27" TV
Sanyo TV DS32224
When I plug the tv in, all i get is a hissing or static sound, no picture or sound. The tv will not turn on. When i unplug the tv, the hissing or static sound goes away. How do I fix the problem? What caused the problem....?
  • 1 more comment
  • CrispyCrunch Dec 18, 2007
    We've the same problem. It is a buzzing sound that is coming from the back of the tv. My husband took the back housing off and we were able to locate the sound near the power supply on the circuit board. What should we do to fix it?
  • amy06 Dec 27, 2007
    when i turn the tv on, it comes on for a second and then automatically turns off. it will do this two times and then it will not come on at all. what can i do to fix this problem?
  • coatl May 11, 2008
    I have sound but no picture. I removed the housing and found that the circuit board behind the tube is broken. I have looked everywhere for a replacement but have had no success. Where might I find a replacement circuit board without driving to Mexico (made in Mexico)?
    President:
  • 3,130 Answers
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Posted on Mar 24, 2006
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
When turning TV on it would click a few time, then you would hear a hissing sound, but no picture. Would have to unplug TV, as it would not power down. Unplugging and plugging in would eventually get...
The hissing sound could be high voltage leaking from a tripler. Observe in a dark room for blue arcing. Look at tripler and connections to the projection tubes. If the tripler is leaking replace the tripler.
Oct 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Component code
codes-0154,0159 this is for the tv
Mar 09, 2009 | Sanyo DS32224 TV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
TV TURNS OFF ON OWN
need to check primary power supply &second power supply . good luck!
Feb 07, 2009 | Sanyo DS32224 TV
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Sanyo DS32224 TV blurry
Do you have the original remote for that TV set? If you do not, you will need to get one or borrow an original Sanyo remote so you can get into the set's menu and go to puicture set up and try adjusting the constrast up a little bit.
Mar 20, 2008 | Televison & Video
Sanyo tv
Try to put DVD conection to your tv if it works normal no problem to your tv, but if sound dosnt work your tv has audio input problem maybe looseboard, or maybe you check the setting for audio.
Oct 03, 2007 | Sanyo DS13204 TV
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
Sanyo DS27910 27" TV Logo
456 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
