I bought a lexmark x2690 printer. It doesn't come with a usb cable, but it is said to be able to connect via wireless network. How is this done?
  • 1 more comment
  • DLVFY Oct 04, 2008
    well, it doesnt give me a cable, plus I would like a wireless setup, like it says is possible in the instructions.
  • Anonymous Dec 04, 2008
    i can't find any way to install it wirelessly! it doesn't come with a cable and then it tells you there's a way to do it wirelessly but doesn't tell you how? really need help. . .
  • MCBD Jan 01, 2009
    I cannot figure out how to setup wireless...
Okay, I just bought this same product. You need to pop the disk into the laptop or computer. If you did not get the disk, get the printer out and set up, then, plug it and afterwards, plug the usb cable to the laptop/computer and the other side in the printer, that way, the computer can recognize the printer. If it still wont do it, call costumer support, maybe the printer and your device are just not compatible.... Good Luck!
Posted on Feb 04, 2009
My computer doesn't recognize my printer
It's possible that the problem is with the USB port on the printer. If you have a router, you can try to connect your printer using an ethernet cable so you won't have to configure your printer using a USB cable.
Once you have connected the printer using an ethernet cable, proceed with the installation in your computer and choose ethernet as the connection type. It should automatically find the printer on your network.
Dec 08, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I am running this Lexmark 6150 printer connected to the computer via usb cable. I have a wireless laptop, how can I print on the Lexmark 6150 from the laptop the laptop is connected to the same modem...
You can enable printer sharing on the computer where the printer is connected, then share the printer so it can be accessed by others on the network. The steps vary depending on which version of Windows the computer is running, so use the help screen. The steps will be listed for you to follow.
On your wireless computer, add the Lexmark printer as a network printer. You will probably need to install the printer drivers, so have the CD handy or download them from Lexmark's website.
Make sure both computers are members of the same workgroup, or the wireless computer won't be able to find the printer on your network. Also, the computer the Lexmark printer is connected to must be on and running for printing over the network.
An easier way to share your printer is by using a USB print server. One example is here. The server connects to your printer by the USB cable, and by an Ethernet cable to one of the wired ports on your router. Then any computer on the network can use the printer at any time.
Jan 09, 2011 | Lexmark X6150 All-In-One InkJet Printer
I have a 905 Lexmark printer and I want to use Smart Solutions. I have a H.P. desktop computer. I assume I would choose "wired" when given an option to choose when choosing a Network...
Lexmark Platinum Pro905 ????
Your Specification Sheet which under STANDARD BOX CONTENTS tells what was shipped with your printer. You should have received a USB cable which you can use to connect your printer to your PC.
If you want to connect to the printer through a wired network (usally via a router) then you will need to purchase a network cable, or rather a Cat. 5e cable of the appropriate length with RJ45 male connectors on both ends. This would be plugged in to the Ethernet port on the back of your computer. The reason for doing this is if you have several computers accessing your network printer they can do this directly without relying on the computer with the printer connection being turned on.
If you do not have a wired network or several computers accessing the printer you do not need to connect a network cable. Windows should detect your printer when you plug in the USB cable; it should not be necessary to work through the Add a printer function.
You don't have to choose 'wired'. You do have the option of setting up a wireless connection to your printer through a wireless network. Your printer has a built in wireless printer server and you can set up your printer to connect to your network without running a network cable.
Suggest you refer to page 101 of the User Guide for details on setting up the wireless network.
Trust this is helpful.
Dec 28, 2010 | Lexmark Office Equipment & Supplies
How do i get the lexmark x4975 working wireless
When setting up a Lexmark printer for wireless use, you must initially have the printer connected via USB. Once setup is completed, then you will have wireless access.
Jun 07, 2010 | Lexmark X4975 3-in-1 Wireless Inkjet...
Don't know where to enter WEP wireless key for Lexmark 5600
If you haven't done so, connect the printer to the network via a network cable. make sure it gets an IP address. Then on a PC, connect to the printer using the IP address the machine gets. You should get it's configuration page. That's where you should be able to enter the details.
Basic information from Lexmark PDF on Installing printer to wireless network
Dec 08, 2009 | Lexmark X6675 All-In-One InkJet Printer
I don't know how to make my Lexmark 4530 print wirelessly. My internet connection is wireless, but I don't know how to get my printer to print wirelessly.
download the installation software from lexmark. You will need to connect it to the computer via a USB cable to run the setup. Just follow the prompts and it will set up the printer on your wireless network. You will run this same software on each additional computer that you want to print to this printer.
Oct 02, 2009 | Lexmark X4530 InkJet Printer
Lexmark X2690 without USB cable
well u must see any new computer store or any used computer store
Jun 20, 2009 | Lexmark X2690 All-In-One InkJet Printer
How do I connect printer to computer there is no usb cord.
buy a usb 2.0 cable they do not come with the cable anymore it is sold sepretly.
May 24, 2009 | Lexmark X2690 All-In-One InkJet Printer
919 people viewed this question
jasbo
jasbo
