Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Hard drive problems
My lacie J 160 GB external hard drive wil no longer boot up. It will power up and then sometimes you'll here the PC make a sound as if its connected but the PC will won't show it. I have to turn the Lace off and on about 50 times before I can get it to work and then it will only stay for about 1 minute. Please help, I have a lot of family photos on there that I would like to copy over to a new hard drive.
  • 1 more comment
  • Hydepark Apr 04, 2008
    I turned off my drive though I left it in place hooked up to an old mac computer for about three weeks.  When I turned it back on it is no longer recognized.  I hooked it up to my new computer (which is a newer Mac with Lacie recognition software) and it also is not seen.  Changed the cable and nothing.  I have had it for about two years and had no problems until now.  I need some stuff I have on it so i really need to bring the thing back.
  • Anonymous Apr 09, 2008
    Hard drive icon appears on my desk top but will not boot up. Has been working perfectly for monthe since first puchased
  • Noel1969 May 20, 2008
    Can see drive, but keeps saying I don't have sufficient power. I cannot see any of the files.
    Novelist:
  • 135 Answers
This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate the bad sectors that won't hold data. Try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O device. Try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. You might not be able to initialize or partition the hard drive on this PC. This may require you to partition and format the drive on a different computer. It's possible that you may need to re-format the drive before it will work again.
Posted on Aug 02, 2007
My 500G Lacie external drive is no longer detected by windows. Sometimes it will say the USB port or device is mulfuction. Sometimes it does not detect it at all.
Does this happen in several computers? If it does, then the interface is probably damaged, in which case you could (at your own risk) disassemble the drive and install the hard drive inside a desktop computer to access your data., since theres a standard SATA hard drive inside.
Mar 21, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
How can I open a LaCie B350 External Hard Drive?
You can carefully pry the bottom off with a screwdriver and remove the drive.  No problem using a "USB to IDE/SATA cable" ( Here's the first hit on Google: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002  Worth $20. ) to copy off your data.  Or you could mount in your desktop PC.
Rob
Jun 26, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
PC no longer recognises LaCie drive
Hi Katya!
There are several possible causes for this. You didn't specify if you're running Windows or Mac so I apologize in advance if some of the information I provide does not apply.
  1. If you recently performed a Windows Update, there's a patch to fix your issue; http://support.microsoft.com/kb/925196#fixit4me
  2. There is a firmware upgrade for your external hard drive. It is located here: http://www.lacie.com/ca/support/drivers/index.htm?id=10007
  3. If the above solutions don't solve your problem, you may try uninstalling the device and reinstalling it. This should clear any communications errors it may have
I do hope I was able to solve your issue. I wish you the best of luck.
Greg
Jun 12, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
External hard drive
I just worked through this same issue with LaCie tech support and they fixed it- it was a bad power supply. Fortunately I had another LaCie drive and when I plugged the power supply from that one in to the "misbehaving" drive, everything booted up fine.
Sep 20, 2008 | LaCie (300770) 250 GB Hard Drive
Shut down lacie
should be a power switch on the back of it. Most external hard drives have to be shut down manually.
Jan 17, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie PC
Try to put hdd in ( for whillem 74) another EXTERNAL!Or just buy new external then put hdd in new external.There is no way to repair it i think!!!
For Fiddler 51 Try hdd in external if it wont acept also then hdd is damanged!
Dec 04, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 160 gb hard drive problem
Did you mess with any Config Files?
Sep 04, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
