Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Signal strength I have a D-Link DI-624 that I have had for a couple of years and I have always been able to get a signal upstairs until about a week and half ago. Now I can only get a signal when I am in the same room. Nothing has changed to my knowledge. Can you please help.
You should also look into the short package preamble option that the 624S has. See set up manual for more details. Also, I added an Airlink 101 7db antenna (see http://www.airlink101.com/products/asb-7ma.php) to my 624S and that helps me get right across all rooms in my house. Problem also is now that I pick up all my neighbours wireless networks so I changed the preamble option to short bursting and I think I've now got better reception through the house - well less dropped packed and slighter fast response times.
Posted on Jan 24, 2009
  • 3 Answers
Your probs gonna need to buy a new wireless router Or a cheap option that may work..... go out to say dicksmith electrical and buy a new more powerful antennae ... this ne w problem has most likely been cause by somone buying a new 2.4g wirelss product
Posted on Sep 15, 2008
    Master:
  • 788 Answers
A few possibilities are new cordless phone, a new wireless router next door, a new cell tower put up near your house. There may be a break in the antennae, try another antennae, they are fairly interchangeable between routers if you have a friend with a wireless router.
Posted on Sep 09, 2008
Not working????
Make sure that the D-Link AirPlus Xtreme G DI-624 Wireless router is functional at 100m signal range for better signal .
Nov 10, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Signal strength very low when down stairs
move the router to the room above the downstairs place of required access and this should solve your problem
transmission of good clear signal is determined by the buildings cosmetic makeup,ie wood seems to be easier for the signals to tranmit thru compared to steel and concrete
Hope thhis helps ,Cheers MISTERDJ
Apr 10, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 always lost connection after use about 10mins. to 20 minutes
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 16, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
D link dir 615. Weak signal, router is put on main floor,but we are only getting 2 bars on the computer upstairs, and almost no signal in the basement. How can we improve the signal or do we have the wrong...
Try turning the router 90 degrees, and measure the strength.
Turn it another 90 degrees, and measure again.
Repeat.
Repeat.
Move to a house with wood cross-beams, instead of metal cross-beams inside the first-floor ceiling.
Rotate the upstairs computer 90 degrees, and measure again.
Buy a "Wireless N" router, for greater signal strength.
Oct 09, 2009 | D-Link DIR-615 Wireless Router
Spare Di-624
Well, if you run a LAN cable from your existing router to the DI-624 in a remote location you could use it as an AP, but this router does not support repeater of bridge modes.
May 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless Router Signal Strength
If is more signal strangth try replacing the atines with an upgrade antinas which you can buy from the routers website
Dec 17, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-link 524 router not working
Double check that you are connected to your router and not a neighbors router.
Mar 29, 2008 | D-Link AirPlus DI-524 Wireless Router
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
96 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
