Question about Cameras
I have a canon EosD20 and it is very slow to write to the card. After I have pressed the shutter button, it takes about 5 or 6 seconds before it takes the picture. This is the same for all the settings; Auto, manual, macro, etc.
Can't get pictures off my EOS D20. Over 100 pictures are not showing up on the CF card.
Posted on Jul 28, 2009
I have a canon powershot a520 and it refreshes vary slow so it takes forever to take another photo. How do I fix this?
I've got a A520 also, and I think theres a few reasons why it can take a while between shots.
1) When using the flash, flash needs several seconds to recharge, this is unavoidable.
2) Some SD cards are slower than others. Make sure you buy a fast one. Note too that a 2Gb or 4Gb card will slow down your camera between shots, compared to a smaller memory card, such as 1Gb, or 512mb.
3) If using a slow shutter speed, such as 10 or 15 seconds, I've found it takes longer to take the next photo. This is unavoidable.
4) You could lower the resolution of the photos you're taking, this will enable you to take photos faster, and may still be good enough for applications such as Facebook, ect.
5) Another trick is to use the multiple shots option. For some reason you can take more photos more quickly than if you manually take each photo. Flash, and slow shutter speeds may still slow down the camera, if used.
Hope these hints help!
Nov 22, 2010 | Canon PowerShot A520 Digital Camera
Will switching to an sdhc memory card make any difference in 'shutter lag time'?
No. The shutter lag is due to the camera needing to focus and meter the light. The size of the memory card makes no difference to the speed. A faster memory card might let you take another picture quicker, but the difference would only be a small fraction of a second.
Shutter lag is simply a fact of life for most point&shoot cameras. You can reduce it somewhat by anticipating the action, pressing the shutter release button halfway to focus and meter, then pressing the button the rest of the way when the action peaks.
Aug 15, 2010 | Canon PowerShot A1100 IS Digital Camera
Sony DSC H-5 Camera slow response time
There is a diaphram between the shutter button and the shutter that does the focus. Pushing the button half way down pre-focuses and then the picture is instantanious. If the diaphram is broken it take a while before the shutter takes the picture. One of the AA batteries may be defective so try another set and see if that is better. There is also a slight possibility that the secondary battery (hidden within the camera) has gone bad.
May 27, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Mar 29, 2009 | Canon EOS Rebel XSi Digital Camera
EOS 30D is slow to fire.
Are you sure you aren't in the delay setting in drive mode? This camera has 2 delay settings, one for 2 seconds between when you press the shutter and when it takes the photo, and one with 10 seconds delay - often used when you want to be in the photo (e.g. self-portrait or group photo).
If you aren't in the delay mode, then I need to know more about your settings. What shooting mode are you using? What type of photo are you trying to take (portrait, landscape, sports)? Are you shooting indoors, outdoors, bright sunlight, overcast, etc.?
Dec 30, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Hi, I have a Canon Power Shot S2 IS 5.0 megapixels that was working fine until one day I changed the memory card from 512MB to a 1GB. Now every time I turn the camera on and try to take a picture, a...
Its possible that there may be an error on the camera try to reset the camera by
1. Turn the mode lever to the camera or play button
2. Press and hold the MENU button for more than 5 seconds.
3, The message "reset settings to default?" appears
4. Use teh arrow buttons to selelct ok. then press the SET button.
5. It should then reset the camera.
AFter doing that and the problem is still there. Format the memory card using the camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 06, 2008 | Canon Cameras
Power Shot A75
Of course it does, it has full manual control (M), but may I suggest first trying "shutter priority" (Tv). This mode lets you set shutter speed up to 15 seconds, but it automatically sets the aperture to match the shutter speed that you set. Merely turn the mode dial to Tv, then use the right/left buttons to select the shutter speed.
Now before pressing the shutter button, may I also suggest that you use the camera's shutter delay timer to take the picture (this will eliminate any shake from you pressing the button). Just press the function button to bring up the menu. then find the timer setting (try 2 seconds).
Here's where you can download your camera's user manual if you want to read more on what your camera can do:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=9828#DownloadDetailAct
Jul 19, 2008 | Canon PowerShot A75 Digital Camera
TROUBLESHOOTING c-750
There are a couple issues related to "slow" that I have with my C-750, and this is how I get around them.
One is the write speed to the xD card. This can prevent you from taking sequential pictures quickly, as the camera displays the current picture it is writing until it finishes. You can make the image of the current picture go away and use your viewfinder again, while the camera is writing the picture, by pressing the shutter button halfway and releasing it. Then you can see your subject in the viewfinder again!
Second is the delay between the time the shutter button is pressed and the time the shutter actually opens (when the camera actually takes the picture). This can be fixed by lining up your shot and pressing the shutter button halfway and holding it for a few seconds. This will give the camera time to adjust and lock focus, shutter speed, etc. There is a small green dot on the display below the battery indicator which will blink a few times when the button is pressed halfway, then remain on steady. When the green dot is steady, the camera is ready. Press the shutter button, and the camera should immediately take the picture.
Nov 12, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Shutter release lag
I suspect a chip in the circuit is heating up and slowing the processing down. It may be a problem that Canon can solve for you. They might even have a modification for it already. Either way you should take it directly to Canon and have them look at it.
Apr 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Slow response time
Before a digital camera is ready to take a picture, the electronics inside the camera must get ready to capture the picture and save it to the memory card or the internal camera memory. Press the shutter button half-way (to its first detent) to set the exposure and focus. When the ready light is green, continue pressing the shutter button completely down to take the picture. The picture is taken almost immediately.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
