Samsung LTN226W 22 in. HDTV-Ready LCD Television
Problem for Samsung LTN226W 22 in. HDTV-Ready LCD Television
Samsung LTN226W 22 in....
By 55chevy3 on Mar 23, 2006
powers on shows picure for seconds then gos off sound still on .turn off then on flashs picture for second then no picture can you help
Same Problem
Jul 10, 2008
-   I have a Samsung LE52M87BD, and regularly the screen goes dark, a few seconds after turning the TV on. I noticed that the backlight is off. Sound etc is still working. Also a buzzing noise is heard at the back of the TV, before the backlight is automatically switched off. This problem always occurs when the TV is turned on the frist time of the day. I then can turn it off and on as often as I can, but only the next day it will function normal again. It first happened once in a few months, now it happens once in a few weeks. -   Reijer
Best Solution
posted on Mar 23, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3610 votes
I'll go through the basics that you can try yourself.
It might be a problem with the backlighting, which usualy is very cheap to fix - take a flash light, dim the lights in the room and flash the light into the screen to see if theres any picture visible.
If so then you're looking at a backlight or backlight inverter failure, like I said, cheap.
second(or first) thing to try is changing the cables you have the TV connected with, they might not be seated well, or have some other problem.
For a tutorial on changing the inverter click here: http://www.lcdpart.com/doc/inverter_inst...
BUT - have a warranty? don't touch it and take it back to the shop.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Feb 23, 2008
Not Rated)
cycus
Rank: Wiz
Rating: 84%, 214 votes
Does the screen light up when the picture is gone?
Was this helpful?
Yes
No
Solution #3
posted on Jan 19, 2007
Not Rated)
jmitsoulis
Rank: Guide
Rating: 91%, 9 votes
Need to replace 2 capacitors in the inverter
Was this helpful?
Yes
No
Popular Solutions for Samsung LTN226W 22 in.
Questions and Unsolved Problems for Samsung LTN226W 22 in.
Do you recommend Samsung LTN226W 22 in. HDTV-Ready LCD Television?
Answer
Answer
I bought this TV just few years ago and paid lot of money for. Just after few months we started... (More)
Answer
Can the backlighting bulb be replaced in a Samsung 46a750 lcd tv?
Answer
my 32 inch samsung lcd tv keeps turning its volume down to zero and stays on the screen so no other... (More)
Answer
Just bought a samsung lcd tv and when I connect cable box I get a great picture but terrible static... (More)
Answer
I have 4 of these units with essentially the same problem, but to different degrees. Using the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung LTN226W 22 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
