Question about Sony DRU 530A DVD±RW Burner
Window driver disabled
Driver for dvd burner disabled. system32/CDRALW2K.sys DVD burns ok but cd have a error message when burning them.
  • Nic Sobo Mar 23, 2006
    I found a resolution on support.microsoft article ID 315345. It involves renaming two files and doing a reg edit. Have not tried it yet but it is well described.
  • dream1autosa May 11, 2010
    My computer no detectrd drive dvd berner
  • 513 Answers
Thanks for sharing the solution, please comment on any news.
Posted on Mar 23, 2006
SOURCE:
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Ok - same itunes error 4280 - but not using a Sony CD and the drive will burn an MP4 dvd - just not CD-r or -rw discs Microsoft Windows Vista Home Premium Edition Service Pack 2 (Build...
Search Results Occurring during an attempt to burn a cd in iTunes, the Burn Error 4280 pop up in a message and is most often a result of the wrong speed of burning in the iTunes program, an issue with the cd drive, or incompatibility between your computer and the cd burner.Sep 9, 2011
Solve Burn Error 4280 with Simple Steps - ErrorAnswers.com
erroranswers.com/pc-performance/solve-burn-error-4280-with-simple-steps/
itunes error 4280 Google Search
Mar 14, 2017 | Samsung SH-S182 DVD±RW Dual Layer Burner
Whenever I try to burn a cd in my DVD ram a message shows up saying it is not accessible, Incorrect function.? What do I do? ive tried to disable and enable the drive then reboot the sys., still the same...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. Thas basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
Nov 07, 2010 | Computers & Internet
Itunes knocks out DVD/CD driver whenever I update Itunes.
Solution 1
Check with your manufacturer to see if there are updated software drivers for your optical drive. For more information about updating the firmware of your CD or DVD drive,
Solution 2
Launch Windows Explorer.
Navigate to C:\Windows\system32\drivers\.
Check to see if either of the following 2 files are present. These files from a third-party software vendor are not supported by Windows Vista and can cause driver conflicts with optical drives:
afs.sys
afs2k.sys
If either of the files in Step 3 are present, move them out of the system32 folder. You should keep these files stored somewhere on your hard drive, as some of your older peripherals may require them. If you find that they are required in the future to use a device, you may move them back into the system32 folder temporarily.
Reboot Windows Vista.
Solution 3
Quit iTunes.
Manually remove the GEAR driver software using the steps found here.
Remove any stand alone GEAR software installers from the Programs and Features control panel, if present.
Install the updated GEAR driver.
Mar 06, 2010 | Toshiba SD-R5272 DVD±RW Burner
My combo DVD drive will burn a CD, but when I put in a blank DVD it just opens the drawer and says to insert a disc. Windows XP.
If it is in fact a Teac CD-Rewritable W58E CD-RW Burner, this will only burn CDs and not DVDs. If you put in a blank DVD you will get this error. You will need a burner that has DVD burning support.
Jan 14, 2010 | Teac CD-Rewritable W58E CD-RW Burner
Burner won't work.
please refer to the burning software recommended by product. you can use also nero 6, 7, & 8. for burning cd's & dvd's.
Aug 15, 2009 | LG (GSA4167BB) DVD RW Dual Layer Burner
I have a lite-on dvdrw sohw-1633s that windows xp will not detect the driver. it shows cdrom.sys driver how do i fix this? I have burned dvd's befor and don't know how or why the driver changed.
Windows xp does not have a native driver for DVD writers. It always detects them as cdrom.sys. You need to use either the writing software supplied with the drive or Nero or equivalent
Jul 02, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
DMA drive error.
Its a problem with the windows dma seting for drives. In "device manager", open properties for ur drive and your interface like IDE/ATA controller. There, you can check and change DMA Settings.
Allow max DMA. Do not disable DMA.
U can also check DMA setting on BIOS if ur bios supports it.
Feb 19, 2008 | Computers & Internet
I need help
Download CDRom.sys or autorunGUI.dll For Free From www.afreedll.com or www.dll-files.com
And Replace The Cdrom.sys into The Windows Folder/System32/drivers/
And AutorunGUI.dll Into The Windows Folder/System32 /
OverWrite The Files If They Ask To Be Overwrited.
Good Day . email : arjunmanoj23@hotmail.com
Jan 10, 2008 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Sony DRU 530A DVD±RW Burner Logo
73 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
