Washer smells like electrical burning
Just replaced the coupler - had the machine on its side several times - put it thru a trial run - works fine, but when starts to spin a whistling sound
appears & smell like electrical short. Whirlpool washer - 11 yrs old.
  • hauseref Apr 28, 2009
    I just changed my coupler too, and now it does the same thing. I noticed that only the front of the motor (at the pump) was hot, but the wires inside the motor were not. I suspect that maybe the bearings on the front of the motor that attaches to the pump may be wearing out. It only does this during the spin cycle.
    Novelist:
  • 166 Answers
Peace aminajmay,
ngafm At your service!
Sounds like an electrical fault.
If I were there hands on I could be definite.
Only a hands on laundry tech can make the diagnoses.
BUT, how old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Thank You
Posted on Sep 09, 2008
I have a Sears Kenmore washer (Model # 11092281100). I replaced the motor coupler, and I checked the alignment of everything before reconnecting the motor clamps/clips. It seemed like the motor shaft was...
It could be the grease. It could run without noise if it was not installed all the way. Here is a link for properly installing Motor coupler video Now if everything looks right it is probally just the grease.
Nov 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer stopped working and smells like it's burning
This would be the motor coupler that has failed common problem and easy to fix. There is a video ( whirlpool style) that will walk you thru the troubleshooting and replacement at www.appliancehelponline.com/servicemanual.html
Mar 27, 2010 | Estate TAWS850PQ
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a Kenmore top-load washer (110.26902691) and just replaced the coupler. Ran a cycle and had a burning smell. Removed the motor and blew air thru it to remove dust and used contact cleaner. tried it...
I'd pull the coupler off again and make sure that the prongs and holes line up correctly. If they weren't aligned when you replaced the coupler, they could be sliding on and rubbing the rubber connector down.
I'd also make sure that the plugs for the motor are correctly in place.
Following is the Whirlpool Service Manual for these machines. It doesn't have a "troubleshooting" answer for a burning smell but you might be better able to diagnose the smell by looking at how the motor connections fit.
Nov 15, 2009 | Kenmore Washing Machines
Smells like motor is burning. during first wash cycle, washer stopped and there was an electrical burning smell??
YOUR WHIRLPOOL WASHER COULD HAVE A MOTOR PROBLEM, IT IS POSSIBLE THAT SOMETHING HAS GOT CAUGHT IN THE MOTORS WINDINGS AND SHORTED IT OUT. IT YOU CAN STILL HEAR THE MOTOR RUNNING BUT THERE IS NO AGITATION IT COULD BE THAT YOUR DIRECT DRIVE COUPLER NEEDS TO BE REPLACED, PART NUMBER IS 285753. THIS IS A COMMON PROBLEM, ESPECIALLY WHEN THE WASHER IS OVERLOADED AND CAN CAUSE A BURNING SMELL SINCE THIS PART IS RUBBER AND PLASTIC. IF YOUR WASHER IS MAKING ANY SORT OF BANGING NOISE THIS COULD BE THE PROBLEM. YOU CAN CHECK THIS BUT IT DOES INVOLVE REMOVING THE PUMP AND MOTOR. ANOTHER POSSIBLE PROBLEM IS THAT THERE IS SIMPLY A BURNED CONNECTION ON YOUR UNITS ELECTRICAL SYSTEM AND IF IT CANNOT BE REPAIRED IT WILL HAVE TO BE REPLACED.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Washer smells like something is burning and it won't work at all
i would check the motor, and also the coupler that mates the motor to the tranny
Nov 26, 2008 | Whirlpool LSR5132PQ Top Load Washer
Replaced Motor Coupling but now I have electrical smell when running
You can test the washer with the case removed by by-passing the lid switch. You will need to jumper the two BLACK wires at the lid switch connector (where it connects to the timer).
With the case removed, and the washer UNPLUGGED. Locate the lid switch connector and jumper the two BLACK wires. Plug washer back in and carefully turn the timer on to start. You will be able to visibly inspect the washer while it is running. The Drive Motor should not start running until the washer fills completely. Set the washer on the lowest water setting to reduce fill time. Usually electrical smells are attributed to the Drive Motor and/or Start Capacitor. Make sure the connectors are all on properly and not loose. Loose or corroded connections can cause arcing and/or burning. Inspect all the wiring for any signs of chaffing or burning. Use caution not to touch any of the electrical connections while the washer is running or energized. Running the washer with the case removed is primarily for giving you a visual for any obvious signs of problems. Any wire and connector checks should be done with power removed. I hope this information helps you. Please post back if you require further assistance.
Jun 05, 2008 | Washing Machines
Burning Smell
no check wiring connector at the motor and the capasitor connectoions, lid switch connections
May 10, 2008 | Washing Machines
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
