Sanyo DS31590 31" TV
Problem for Sanyo DS31590 31" TV
Cable Connector inside TV
By Rockstar on Mar 23, 2006
My cable connector on the tv has been destroyed. The male connector is bent and the wire inside the television has been pulled off. The TV works fine except I cannot connect cable. How and what do I use to replace the broken one??
Same Problem
Jun 23, 2008
-   The Cable Connector has broken off the RCA TV (F25305). The picture is great - the sound is fine - but the connection for the coaxial cable popped off. Is there an inexpensive part somewhere that can easily replace this?-   WindCrying
Best Solution
posted on Mar 24, 2006
Helpful)
techman
Rank: Guru  Sanyo Televisions & Videos  Expert
Rating: 86%, 7687 votes
Unless you know how to sholder well and know how to do an isolation test on the set after its repaired I would let a pro do it My friend as I've seen it a hundred times. A peep will simply hook up a connector to the set and ground the connector or what looks like a ground and as soon as that set is pluged into an ac outlet and a cable or sat line is attached KAPOWWWWEEYYY.. It smokes and you end up blowing out the bridge rectifiers aong with all sorts of things. Now dont get me wrong please as you can repair set if and only if you wanna take that chance by simply taking a piece of coax cable with a connector on one end and soldering the center wire onto the broken wire that came off the connector and then soldering the outside or sheild wire to the place where the broken connector was attached if at all possible BUT I repeat this is not a good way to do this. Good luck
Was this helpful?
Yes
No
Solution #2
posted on Feb 17, 2009
Not Rated)
cconnector01
Rank: Apprentice
Rating: 0%, 0 votes
You need to find the good for your TV. It should prevent and protect the heat. The cable connector should be of good brand. If you need the best connectors, you can visit the website below.
http://www.compressionconnector.com
Was this helpful?
Yes
No
Popular Solutions for Sanyo DS31590 31" TV
Questions and Unsolved Problems for Sanyo DS31590 31" TV
Do you recommend Sanyo DS31590 31" TV?
Answer
Answer
Picture is dark, tried to brighten under menu, still dark
Answer
I have a sanyo ds31590 31" tv and i cannot find how to change the input selections. all i can... (More)
Answer
la pantalla se ve en blanco y todo parece funcionar normal
Answer
I am trying to play a game what channel do i turn to for video
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in Beverly Hills, CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
