Question about Panasonic NV-SJ205 VHS VCR
Panasonic NV SJ205 changing RF settings
Thanks for advice, using cables helped to play video, but now am not able to record from tv. Is there a way to change RF settings? What is the usual method with Panasonic video machines ?
Thanks Dan
Going crazy in Cape Town
  • Anonymous Feb 07, 2009
    I had the same problem, that I got stuck with for several days, and I just wanted to say thanks because this post saved my tv (from being replaced).
Hi.. have your solve the problem?
To change channel, hold down MENU button in the remote control for 5 seconds or more, the VCR display will come up. Enter the desired channel numberby channel button. Press MENU button to finish setting. Re tune your TV to the new RF channel..
Posted on Oct 28, 2008
  • 10,594 Answers
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Posted on Sep 09, 2008
How to go to the screen to set to record a program
Would the instruction manual help? You can download them free from the Panasonic website.
Sep 21, 2010 | Panasonic NV-SJ205 VHS VCR
I have a panasonic NV370 video machine there is sound but no picture any advise on how to fix the problem
If this problem happens when a video is being played back all you need to do is clean the video head. I would use Servisol Video 40. The best way is to take the top off and give it a good clean wherever the tape comes into contact.
May 05, 2010 | Panasonic NV-SJ205 VHS VCR
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
Panasonic nv Ds30en
I have apanasonic NV DS30 play problem after capturing they could not play
Jan 29, 2009 | Panasonic NV-DS30B Mini DV Digital...
Panasonic nv gs50 camcorder not recording images
Try using a different tape or cd. It could be faulty media.
Jan 05, 2009 | Panasonic NV-GS50 Mini DV Digital...
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
My 83 year old dad wants to hook up a VCR to his television do you have inbstructions?Thanks
ok one normal coaxal lead in goes in to the back of the tv were the areal goes and into the vcr rf out put
the areal from the roof goes into the areail on the back of the vcr
Jul 04, 2008 | Panasonic NV-SJ205 VHS VCR
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
Problem in connecting Camcorder with Laptop
Use USB data cable which u get with ur cam.Install the panasonic software also packed with cam.And get ur video copied to pc.But this is a slow process because of Movie copied while playing.
Regards,
Sandeep
Oct 23, 2007 | Panasonic NV-GS15 Mini DV Digital...
Panasonic NV-SJ205 VHS VCR Logo
474 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
