Question about SanDisk Sansa Clip MP3 Player
Sansa clip i still need help realize my sansa clip on my computer.
  • emgarner Dec 01, 2008
    my sansa player does not show up in the device corner in Windows media even though it is listed in device manager.
  • Anonymous Dec 02, 2008
    I can't figure out how to take songs off as well as put them on
  • 24 Answers
If you go into Windows media player, you should be able to recognize your sansa clip from there. It will be on the right hand side panel... Let me know if you need anymore assistance.
Posted on Sep 12, 2008
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
I have a sansa clip mp3 player and I lost the disk???
It should be recognized by your computer. I did a search for drivers and they are not needed for this model.
For music, After the computer has recognized it has been plugged in. Start, My Computer, and it should show up in there as (my sansa or sansa clip) something along those lines.
You may open it and drag your music files into the accroding folders inside the device.
OR You may use Windows Media Player 11 to Sync to your Mp3 Player. The Sansa Clip has problems with Windows Media Player 10 so i would reccomend using Media Player 11 to sync.
For future help or more questions please comment,
I hope this has helped :)
Feb 19, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Won't turn on
What you need to do is first make sure that you are safely disconnecting your sansa clip and not just taking it off the computer. Second you may have a virus in your sansa clip I would prefer you call Technical Support for Sansa clips, the number is 1-866-726-3475, they are open 4am-10pm PST
or 7am-1am EST. Hope this helps
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip
You don't need Vista to install the Sansa Clip. Run the installation CD (or grab the software from Sandisk's website), and plug the player into your computer.
Jul 06, 2008 | SanDisk Sansa Clip MP3 Player
Quick question!!
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 20, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip; Does not appear on icons
unplug Sansa MP3 player from your PC, go to menu ->settings, scroll down to USB-Mode, change mode from MTP to MSC, re-connect, yout PC will connect, detect new usb devive, disk drive.... and your sansa icon will be displayed at computer folder.
Good Luck
Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
