New contacts and new control board. A/C unit will not start. When you manually close contacts the compressor will not kick on. The fan motor will run when contacts are manuall closed
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Sounds like the capicator is bad Also backtrack from the contactor for 24-volt power all the way back to the unit. or go to the thermostat, remove the cover and jump the red wire(power) to y=cool!
Posted on Sep 09, 2008
Hooked up new 4 wire fan 2 condensor with a new 2 cap fan runs fine but no compresor?installed as was told with nothing runnng 2 the new cap but the brown wires but compresor isnt kicking on
The compressor could be bad there is two ways to tell with an ohm meter check each lead off the compressor and to ground for continunity or a megometer . You can always try a hard start kit. It is a super capicator that multiplies starting voltage. Have you checked all connections? There might be a low\ high Pressure switch in the referigent lines if that is bad it won't allow the unit to start. Also is it a heat pump or straight a/c the heat pumps have circut control boards in the unit that control everything
Aug 07, 2011 | Goodman CLQ36AR49 Air Conditioner
We replaced the compacitor, when you turn the control on inside the outside unit clicks and starts to hum, you can hear the new comp running. The fan will not kick on. All of the wires are connected and...
You have to replace the capacitor whenever you replace a compressor. You may have a bad fan motor as well usually when capacitors go bad the motor isnt far behind. This unit will have a dual capacitor for the fan and the compressor and yes one side can go bad and the other side be good. Replace the capacitor and let me know
Jul 21, 2011 | Ruud UBHC Air Conditioner
Contact points on compreessor motor are sticking closed and unit (compressor) does not kick on. No breakers are kicked, when I cycle them the contacts keep locking closed and compressor remains off.
Contacts are bad need new contactor. This happens often, Check out very carefully to see why contacts are going bad. May need new capacitor.
If you have voltmeter check the compressor side of the contactor to see if you have voltage. Rus
Jul 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Condesor fan stops working
is it one of those Smart motors? it is there save on the electric bill. you actually only need a motor that run fast enough to remove the heat from the coils,one speed you just do not get power saving.
Jul 04, 2009 | Heating & Cooling
Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Jun 13, 2009 | Goodman CKL24AR24 Air Conditioner
Connecting a motor starting capacitor
New Capacitor
herm start on the compressor
fan start on fan motor
c run or power to both compressor and fan
Apr 25, 2009 | Kenmore 75085 Air Conditioner
Outdoor fan motor is not running fast enough?
Check to make sure that you have the correct voltage going to the motor. It sounds like you lost one of your legs of power which would give you 110v instead of 220v. Or it could be in the pc board.
Oct 15, 2008 | Hitachi RAS-09UH Air Conditioner
Blower fan runs continually with the thermostat removed or installed. This is a older carrier combined unit with a furnace. Control board installed is a HH84AA 011. Replaced the board with a new board and...
your sensor to the fan is stuck in the closed position. This sensor kicks the fan on when a certain temp is reached in the heat chamber. It opens after cool down and apparently is stuck closed.
Jun 25, 2008 | Heating & Cooling
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
