Konica 3135 my copier says error f67 wich I know is the rdh or radf? is it something easy to fix? what do I need to do?
  • 1,326 Answers
Here are a few fix's to try... Have you turn the copier OFF and unplug the ADF for a minute or two, then plug it back in and turn the copier back On. Also, have you cleaned or replaced the small refectors in the feeder? How about the interface cable of the ADF, there a two diffent one's, depends on the feeder type. Have cleaned or replaced the two switches on the right rear side of the ADF. I've seen that cause alot of problems with that series of copiers. There is a up-date kit with a Gold spring an mountting bracket and switchs. It could be the PCB also, but mostly the switchs.
Posted on Sep 10, 2008
    Problem Solver:
  • 13 Answers
It could be the encoder, either there's dust trapped in it or it's not turning which would be a drive problem or, and this is the worst, the photo emitter is blown.
Try a can of compressed air into the sensor towers, make sure you hold the can level so as not to freeze the assembly.
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Registration
you copy registration, w/out RADF? Or RADF registration adjustment?
Jul 02, 2009 | Sharp AR C250A Color Copier
Konica 3135 error code f 43 ( exposure lamp)
The exposure lamp is located in the scanning area beneath the glass. If you choose to do it yourself you can purchase a lamp here
https://www.interlight.biz/light-bulb/252254045&ID=FROOGLE-US
You can get the manual here
http://www.service-manual.net
Be sure to follow the steps closely it is easy to do more damage than good in that area if you try to wing it. Good Luck
Apr 20, 2009 | Toshiba E-Studio 161 Copier
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 error code 41
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Jun 26, 2008 | Office Equipment & Supplies
Copier: Konica 3135 p.81 Insert key counter
you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Oct 16, 2007 | Office Equipment & Supplies
107 people viewed this question
k24674
jasbo
jasbo
