Question about Polaroid 8" Portable DVD Player, PDV-0813A
DVD player only reads CD's and not DVD's
Whene i put my DVD in my player it always sead no disk.
  • 2 more comments
  • mtnmann9 Nov 28, 2007
    DHM-0100 -> It plays CDs, but DVDs just spin and spin until it finally says "No Disc". I cleaned the lens to no avail. This seemed to happen sporadically at first, but now I can never get the DVD to finish loading...
    Player is about 2 years old and not used to often.
  • nelson1 Jan 09, 2008
    Same problem - only reads CD's not DVD's lens has been cleaned
  • rositaperez Feb 11, 2008
    my dvd is over a year old and I used it very often, almost daily but now does not read DVD (NO DISC) and for movies it will display (DISC ERROR)
    I reset the system, unplugged, turned it off and nothing, what should I do???
    Thanks
  • jpolett Jul 30, 2008
    Brand new GPX D1816 reads my DVDs fine, but says "no disc" when I insert a music CD or a picture (jpeg) CD. It is supposed to play all. All I have connected are the red/white/yellow cable. Do I need to buy another cable of some kind to get the CD or Pictures?
    President:
  • 3,130 Answers
When was the last time you cleaned the lens on the laser with a cleaning disc?? you also didnt say how old it was asit could also be the end of the lasers useable life??
Posted on Mar 24, 2006
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | Televison & Video
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
NO DISK
Unit may have defective optical pick-up. Or make sure disk is not in up side down. Or it may have processor lock up -- unplug for 24 hours
Apr 21, 2008 | LG DN191H DVD Player
Check disc
Is the surface or your disk smudged or damaged? If not, try a lens cleaner CD or kit and see if the problem goes away. If they are DVD Rs or something similar(DVD-RAM, DVD+R, ETC) the player may not be able to play that particular format, and you should double check the instruction manual to see what types of disks can be read.
Nov 08, 2007 | Sony DVP-FX810 Portable DVD Player
Televison & Video Logo
1,094 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
