Question about Philips 60PP9352 60" Rear Projection Television
When turning on my tv, the screen doesn't come on but it makes a constant chirping sound. Like it wants to turn on but doesn't.
5 Suggested Answers
SOURCE:
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
Me too! help!
Posted on Apr 28, 2008
MikeNJ1964
  • 398 Answers
SOURCE: when tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Posted on Jun 28, 2007
Ecollier2012
  • 3459 Answers
SOURCE: tv has no sound or picture just chirps
On this particular model the most likely cause is the convergence ICs are shorted. Its very common. Goto www.TvRepairKits.com to get their complete kit for the chirping set. It includes all of the parts to do the repair it one shot. The kits also include step by step photo instructions. This is a common problem on this magnavox model.
Posted on May 22, 2009
  • 57 Answers
SOURCE: Chirping beeping noise coming from rear will not turn on
Power card defective,in power card main filter defective.
Posted on Jul 05, 2009
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
Constant clicking sound when turned on....no picture....looks like TV isn't on. You only hear the constant clicking. You have to cut power to stop it.....hitting the power button on the TV doesn't...
Sounds like bulb is burnt out. Have replaced its the cheapest way to go. It may be a power board but if its out of its warrenty, then you may just want to buy a new set.
Aug 02, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv turns on then right back off
Does if make a chirp sound? If so see below...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2010 | Philips 46PP9302 46" Rear Projection...
No Sound, No Picture on Magnavox 51MP392H/17
If you hear a constant clicking or chirping sound get the chirping TV repair kit from www.TvRepairKits.com
If you have no video - but have audio - its most likey the HVG.
Note: When the video goes out sometimes its hard to tell if you have audio becuase you can't see the screen to change to the correct channel.
May 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
When tv turned screen is blank and chirping sound comes from back
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
