Model: Indesit D41 Before starting a new cycle you first need to select reset on the dial. When doing this, the drainage pump operates for about a minute followed by the pre-wash light blinking indefinitely and I cannot get a washing cycle to start. There is no water present at bottom of unit and I have tried pouring a basin of water into the unit and repeating the procedure. The water is pumped out but the cycle refuses to initiate. The indesit helpline have suggested that there is a leak in the base and water is trapped in the base, can this easily be fixed?
-   Our WHIRLPOOL DISHWASHER MODEL GU2500XTP had the Accu Sensor light blinking constantly and it would not turn off. Tried unplugging the unit, resetting the fuse, pushing cancel button etc. Had problems re-starting the cycle. Read this article solution and tried it holding Normal Wash Button with Heated Dry, after several sessions of doing this it reset the dishwasher.
Thank You
-   Guest
Feb 19, 2008
-   WHEN TRYING TO START A NEW LOAD THE MOTOR IS RUNNING BUT THE GREEN LIGHT SHOULD STAY SOLID BUT IT STARTS TO FLASH RAPIDLY AND THE MACHINE WONT GO ANY FURTHER . NO WATER IS ENTERING-   MOLLOY-2008
It look like you have a cold water supply problem- check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open). Check that water entrance valve work (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
I have had the same problem. The issue is with the dip tray + overflow detector under the machine. What happened is the dip tray is full of water and the overflow detects this condition and prevents the machine from starting. It looks like there is no water present in the machine but the drip tray, located underneath, is full. Give the machine a good shake and you should see water. I solved it easily: just get a mop, lift the machine's front so that it tilts backwards and collect the water as it escapes the drip tray towards the back of the machine. The tray can collect quite a bit of water so you're likely to need a few tilts until it's empty. In my case, the underlying case had been a previous mistake - we didn't allow the machine to finish completely and water had remained on it. Somehow the water had found its way to the tray. Other causes my be another appliance sharing the same waste pipe and pushing water down the dishwasher's waste system.
Comments:
Nov 12, 2008
- Underlying cause may also be the machine being at an angle. Make sure yours is level or has a slight inclination to the front (just a few degrees). This prevents water from going into the dip tray too easily.
Dishwasher idl40t error lights 2 and 3 flashing rapidly after two minutes, Ive checked water supply...
(More)
Dishwasher idl40t error lights 2 and 3 flashing rapidly after two minutes, Ive checked water supply which seems ok.
HI, I hope you can help! A chopping board fell of the top of my fridge and went down the ''baskety...
(More)
HI, I hope you can help! A chopping board fell of the top of my fridge and went down the ''baskety thing'' at the back, I got the chopping board back out but noticed that a pipe had been knocked out of the back of the fridge. I think it is the pipe that runs the water to the dish at the back. So I pushed the pipe back into a hole where it looked like it came from, but didn't secure it or anything. Now I am too scared to switch my fridge back on because of water and electrics. Would be so grateful for any advice Samantha
I have a Indesit IDL40 dishwasher, which was purchased less than 2 years ago. It has now developed a...
(More)
I have a Indesit IDL40 dishwasher, which was purchased less than 2 years ago. It has now developed a fault where the machine starts with the 2nd light on. It then sounds like it is filling up with water but within a minute the 2nd and 4th lights start flashing and the machine stops!!! Can you please offer any assistance? Thanking you in advance.
My Indesit DI62's overflow cut-off has triggered, and I need to drain the basetray, but Idon't know...
(More)
My Indesit DI62's overflow cut-off has triggered, and I need to drain the basetray, but Idon't know how to access it.
