Mitsubishi WD-62525 Red Status Light After Cap Replacement
I just finished replacing 6 CAPs on my power board after having the flashing green power led symptom.
After putting the set back together I get the steady red status led and the error code indicates 41 (short detected).
Any suggestions.
PS. I replaced two caps on the power board 6 months ago and the TV worked fine after words.
  • 125 Answers
Maybe this help you, let me know. good luck
ok here new tips on v26 chaiss cust install new oem lamp with led lamp just blink only many time install new balister still shut down no audio no hv at all come with code 34 for test turn out to be that in power supply ther caps that wher blow up 3300 mf at 16v two them c9a38 ad c9a36 both same also note c9a62 1000mf at 16v thru c9a52 ad c9a82 ad c9a61 all 1000mf at 16v install 63v at 1000mf all same with both 3300mf at 25v fix the set now turn on with great pix cust old lamp too dark for pic install new lamp pic better ad reset lamp timer all good cust happy that cust got from mist the power supply board from looking from back of the set on left hand side all way in front u hav pull whole dmb bd to get to it want lets yu guys know[john leyva american video service center ] the right model number is this WD52525 HIT BAD KEY THIS RIGHT MODEL NO WD52525
Posted on Sep 10, 2008
Mitsubishi WD-62525 3 fast red lights then 1 long repeating
Not sure if they can be swapped out....you may want to get the schematics or service manuals and check
Apr 29, 2013 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green timer light after power outage.
Failed capacitors on the DM and the Power boards. You can get the V26 Chassis DM/ Power repair kit from www.tvrepairworld.com which contains the replacement caps and the CD with instructions.
Aug 06, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green light in front of tv and no picture. On a Mitsubishi 62525 projection tv
This problem is bad capacitors on several circuit boards inside. They are solder in parts and replacement requires extensive disassembly. Repair estimate = 200-500$
If you can solder and have disassembly skills, I can talk you through the repair with about $30 in parts and a few hours of time. Let me know if I can be of more assistance.
8-12 1000uf 16v caps = replace with 680uf @16v
possible 2 bad caps on power supply too.. 2200uf or 3300uf I cannot remember. All are labeled and will be obvious. Check my bulletin on bulged caps. http://www.fixya.com/support/r5000889-repairing_tv_just_clicks_over_over
Jun 04, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Have green light from hell replaced caps on power supply stillhave green light from hell wich board is the dm board
Chassi will have to be removed and sent to Mitsubishi for rebuild. It takes them a long time to get it back to you.
Nov 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Constant flashing green light
I had the same problem. When I checked the lamp (that was only 6 months old) it looked good. I had a tech come out and he put in a new lamp and solved the problem.
Good Luck!
Apr 14, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 I have the flashing green light problem. Unplugged the power srtip this morning, When I got home tonight plugged it back in and the green light flashes 12 times, pauses then flashes 12...
there are many capacitors that leak on this set and chances are that some of them were missed. Sorry you spent so much money on that repair but Mitsubishi service could have fixed it right for $300.00 because they know where all of the caps are and they burn it it for several days before it leave the service center.
Jan 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
