Question about Fortec Star Lifetime ULTRA
Fortec Innovative problem
Like others I can no longer dowload updates direct from my router - I get the message 'Network established but disconnected (98)'. I have checked Gateway and DNS are the same, have it on DHCP, in 'IP Mode' and 'Local IP', but still I can't get the thing to connect.
Can you help, please?
  • 19,396 Answers
You get this message also when there is no new update. tell me the model number and I will check updates for your router.
Posted on Sep 09, 2008
  • Ginko
    Ginko Sep 09, 2008
    Try also the following:
    0-Disable all firewalls.
    1- Connect the router to your computerusing a network cable.
    2- Open Start >> Connect to >> Show all connections
    3- Right click on 'Local Area Connectio'n and choose properties, then scroll down and double click on 'Internet protocol TCP/IP'.
    4- tick on 'use the following Ip Address' and use this address:-
    Ip Address: 192.168.0.1
    Subnet mask: 255.255.255.0
    Just fill these two and leave the rest Blank, then click OK.
    5- now go again to Start >> Connect to >> Show all
    connections. This time right click on 'Wireless Network
    Connection' .
    6- Go to 'Advanced' then tick on 'Allow other network ...' and choose 'Local Area Connection, from the list, then click OK.
    7- now connect to the Internet and see if it works.
  • Ginko
    Ginko Sep 09, 2008
    Hi, you need to connect to the router using an ethernet cable, and not in wireless mode.
    If you are using wireless, that can be the cause of the problem.
    Disable all firewalls on the computer you are using. Also firewalls can block the network.
    If it still does not work it Depends on Fortec, in some way they are
    cutting you out from the network. Ensure that you are entitled to
    download codes, it looks like their server is cutting out your IP right
    after you connect to the network.
    First ensure that you are entitled to download codes if you are not
    this can be normal, after a while they can spot and block an IP. Give
    them a call to ensure it is not that your IP had been blocked.
    If your account is fine, try updating receiver firmware.
    Here is the download page
Every time i put a password on my N1 Router i lose connection and get the message: The set-up in my computer does not match the set-up of the network??????
Existing connections need to be re-validated. The prompt is a general message asking you to re-enter your password (the new one) to establich a connection to your laptop. The "set-up" that no longer matches is the lod password versus the new password. The connection should be re-established once you enter the new password. All other computers connected with experience the same message.
Dec 31, 2010 | Computers & Internet
It says that my wireless is connected, but I cannot get onto the internet
I found that drivers of the wireless card may not work with the latest drivers of the router. As was in my case. I updated my router. All good. Updated my wireless drivers on laptop, I see network but can not access it (Dell says they are still working on it). However, I could connect to other wireless connections. So it was the Dell card for sure.
Did you recently update any drivers? Maybe try rolling back. If not, maybe try updating them and the router.
Sep 22, 2010 | Computers & Internet
Router not working at all!
Go to Control Panel- Network Connections-Network Connections and look for anything that says VPN or PPTP. Right-click on it and click disable.
Go back to your browser- click on Tools- Internet Options-Network Connection and make sure Never Dial A Connection is enabled. Click on LAN settings and make sure nothing is checked. Click OK.
Try to log back in to your router by tying in 192.168.1.1 and reconfigure the settings again.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Network problem Mac Powerbook 1.67
I am going to do two things, here.
1.Solve your problem
2.Suggest a program I highly recommend which will prevent your problem's reoccurence, though I have absolutely no financial interest in the latter, but have used it when problems like this occurred and it has proven itself to be the only way I know to properly administer a home network of up to 8 nodes with minimal difficulty.
First, the solution, since your previous addition of a router, which you removed, very likely consumed and still consumes an allocation of memory reserved for it, which your mac PB can no longer address, as it once could.
Start from scratch and rebuild your network, running whatever setup procedures established the relationship between the nodes.
Next: Google Network Magic, download the free version to try out, and if you like it, buy the program which probably currently sells for about $50.00, fully configured. There is also a Mac version which will assist your mixed network needs.
Mar 30, 2009 | Computers & Internet
Keep getting message that cable has been disconnected..
First off, you need to update Windows.Go to where your modem is, unplug the ethernet cable from the router and connect direct to your computer, and run Windows update. You may have to reboot several times before all the updates have been implemented.
Then, the flag message you have been getting "cable disconnected" indicates to me that the flag is coming from the internal network card of your computer, not the wireless client in the computer. You need to make sure the wireless client is setup properly to see the router.
Do you know if security has been setup on the router? If so, we will need to walk down that road to get it set up on your laptop.
But first things first. Get the computer updated, and reply back answers tot he above, as well as what Operating System,s you are running.
Feb 04, 2009 | 2wire Computers & Internet
Fortec Innovative
If it still does not work it Depends on Fortec, in some way they are cutting you out from the network. Ensure that you are entitled to download codes, it looks like their server is cutting out your IP right after you connect to the network.
First ensure that you are entitled to download codes if you are not this can be normal, after a while they can spot and block an IP. Give them a call to ensure it is not that your IP had been blocked.
Sep 09, 2008 | Fortec Star Lifetime ULTRA
GULF- FORTEC 5600 II NOT WORKING
Have the same problem since one week now 'network established but disconnected !. I have fortec lifetime II receiver. I have ver 6.1.0 and trying to download 6.1.29 using com port from PC, no success. keep getting error ' downloading not requested'. it's a mess !
Aug 18, 2008 | Fortec Star Lifetime ULTRA
NIC blinks on then off for longer run lines
You need to update the firmware of the router then hard reset it.
Download the router's firmware at www.linksys.com/download
After updating the firmware, you need to hard reset the router.
Press the reset button at the back of the router for 30 seconds then unplug the power for 30 secs then plug it back in. That should fix it.
Jul 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Up grading Fortec Star (Lifetime II) reciever.
my fortec star reciever is not up grading through (Action HBS link box) to open Showtime program
Apr 25, 2008 | Fortec Star Lifetime ULTRA
Loss of connection
This problem is mainly cause by the router firmware, so I advuice you to contact Netgear and ask them to update the firmware of your router to resolve this problem that you have....
Apr 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Televison & Video Logo
82 people viewed this question
Top Fortec Star Televison & Video Experts
Jaime Hernandez
Grantec 2000
Level 1 Expert
Barry Barrett
Are you a Fortec Star Televison and Video Expert? Answer questions, earn points and help others
