Question about HP DeskJet 9800 InkJet Printer
Print job prints larger than actual file
It doesn't matter what size of paper I print with my printer enlarges it. For example, I have a 12" x 12" file. I drag and drop it on a 13" x 19" canvas. According to the ruler in PS CS3 it remains at 12" x 12" on the 13" x 19" canvas. When I print it the 12 x 12 picture ends up being 3/8 of inch wider. Any ideas what may be causing this.
All Office
  • 58 Answers
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Posted on Jul 03, 2007
MUKHTAR
  • 2022 Answers
SOURCE: printer won't print
switch of the printer first remove the usb cable from the printer and uninstall the printer driver nad remove printer from device manager also. to go to the device manager do these steps first right click on my computer and then go to properties and the click on hardware tab and then click on device manager and go to universal serial bus controllers just click on + tab it will expand and it will show the list of connected hardware select usb printing support and right click on and uninstall then restart you system. after coplete boot run the driver software and connect the usb cable when it will prompt you and switch on the printer. it will install your printer
Posted on Sep 22, 2007
SOURCE: Printing PDF files
I had this problem after I had fixed a problem printing from Quicken. I was able to print from Quicken by changing the print option in Windows -- mine was set to "Spool documents" and I changed it to "Print directly from printer" -- the advice I was given was to change it from whatever it was set at to the other option. For printing a PDF file, I changed it back to "Spool documents" and it allowed me to print the PDF file. Try this and see if it works for you -- click the Windows Start button and select Settings, then Printers and Faxes. Right click on the selected printer and select Properties. In the properties window look for a setting to print directly to printer or spool documents -- mine was under the Advanced option. Try the option not currently selected -- in my case, I changed it back to Spool documents with Begin printing immediately -- and then try to print a PDF file. It looks like I will have to toggle back and forth when I am printing from Quicken and when I am printing a PDF file. Hope this works for you.
Posted on Apr 18, 2008
SOURCE: paper mismatch
you have to load the printer driver for HP Deskjet 990c. This worked for me perfectly and I'm sitting here printing my wedding invites right now! Good luck!
Posted on Jun 15, 2008
SOURCE: Cannot print on regular letter size paper on my HP
I had same problem. Try this: When you go to print, change your ink quality to "draft". For some reason, I was able to print after trying everything. Hope this works for you!
Posted on Feb 18, 2011
"Paper detected does not match paper size. or type selected. Make sure the paper size is correct to continue the job" This is now on the display window. Nno changes were made. Help!
You give no details what job has been sent to the printer before that. Probably your printer settings about the paper are some standard for your area like A4 for example, but you are trying to print a file, received from a place on earth, where the paper used in printers is different format and the file has been prepared for print on Legal, for example. To reset the process, find the print job in your Devices and Printers folder and delete it. Then power cycle the printer. Then check the document and make ajustments to it fitting the printer settings. Then print it again.
May 06, 2015 | HP OfficeJet Office Equipment & Supplies
Epson 600 stuck on making 3 copies,no matter if i set it for one copy
Select Basic Print Options After opening your file for printing, open the Print window to select your print options. 1. Open the File menu and select Print. 2. Click the arrow to expand the Print window, if necessary. wf600.1.86.1.jpg 3. Select EPSON WorkForce 600 as the Printer setting. wf600.1.86.2.jpg 4. Select the copies and pages settings for your print job. Note:
If you don't see these settings here, check for them in your application before printing. 5. Select page setup options. Use these options to select the paper size, orientation, and scale. Note:
If you don't see these settings here, check for them in your application before printing. For example, you may be able to open the File menu and select Page Setup. 6. Select any settings that are specific to the application you're using. For example, if you're printing a photo from Preview, you see the application settings shown above.
If you have any doubt in this pls click here
Jul 26, 2011 | Epson WorkForce 600 All-In-One InkJet...
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
Trying to enlarge print
before you print, select all the text and resize it to a higher number (say from 12 point to 14 point) then print, (but dont save). that may help. The problem is, your resolution is larger than the actual size of the item, so you are getting a 'magnified' look at the screen. So anything normal on screen will be smaller when printed.
Jun 30, 2010 | Dell All-in-One Printer 810 with 2-Year...
Canon W8400 printing.
Hi Did you get an answer I have the same problem.
Tony
May 24, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Recently I have gotten a message,
The application you are using is calling for a specific size or type paper in tray 1.
For example, you have "Executive" size paper and the job needs Letter size.
Easiest fix is to make sure your "Page Set-up" matches what you have in Tray.
Failing that, you can also, open tray 1, pull it most of the way out and then push it back in. This will force a re-read of the paper size. Then press the "Green" button.
If it still happens, use the "Print To File" check-box on the Printer Properties screen and then name the print file something like "tray1fail" and send it to me at don.farr@hotmail.com and I'll be happy to run it through some of my file readers and tell you what the print job is looking for. There is no fee or charge for this. I actually enjoy reading print files.
Don
Feb 11, 2010 | Lexmark Optra S 1625 Laser Printer
How do I enlarge the print on an Epson Stylus CX9400 fax series?
the printing wizard it has the size choice ...but the actual size its established by the limitations of the printer ..anyway all documents may be re-sized in the computer and than printed...even in pieces and reattached after if the printer supports only A4 paper maximum
Sep 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Epson LQ -590 PRINTER PROBLEM
  1. You text page is larger than the printer page,
    margins are set wrong, or there are special
    formatting marks and/or characters at the end
    of your documents.
  2. Check default printer paper-size settings:
    START --> Printers & Faxes -> Chose printer -->
    right-click --> properties --> ....
    This sets the default settings, that are in effect every time
    an application starts up.
    Also note, that if printer settings are not listed within
    your START menu, you can find them in the Windows
    control panel. You can change what shows in the
    START menu and what doesn't by right-clicking the
    task bar.
  3. Now start your application and do the same thing under
    the file menu:
    File --> Print --> Settings ...
    File --> Printer settings ...
    File --> Page setup .... and also margins. etc...
    This sets the actual settings for this application or the
    current document. These settings over-ride the global
    default setting in item (2)
  4. To clarify, the settings in item (2) should be setup to
    reflect the way you use the printer the most often.
    The settings in item (3) reflect the actual document you
    are trying to print now.
  5. Be careful that the paper size settings (3) accurately
    reflect the paper in the machine, do not confuse
    metric sizes: A1, A2, A3, A4, A5 ....
    with English sizes: Letter, Legal,..... etc
    These do not line up exactly.
  6. Also check your document, to make sure that there
    are no extra characters at the end of your document:
    Paragraph marks, Page Brakes, Form Feeds, etc.
    Also check the paragraph settings (in Word for Windows,
    for example, to make sure that is not the cause of the
    problem.
    In word for Windows, for example, you can also go
    into tools, options and change the way your document
    is displayed, such that all formatting marks become
    visible (or click on the paragraph tool)
  7. Finally, most Windows applications offer some kind
    of print PREVIEW facility, so that you can see what
    you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
Jul 17, 2008 | Epson LQ-590 Matrix Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
HP DeskJet 9800 InkJet Printer Logo
81 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
