Question about HP LaserJet 3600dn Printer
Error code 54.18
When printing several pages at a time the printer gets jamed up...
    Habit-Forming:
  • 8 Answers
The error code 54.18 means that there was an error with black toner cartridge toner level sensor. Try taking the cartridge out and shake it a little to loosen up the toner inside, make sure all of the cartridge metal electrical contacts are clean and try it again. If it still has a problem you should try a new black toner cartridge. If that doesn't change things then you may need to replace the DC controller.
Posted on Apr 16, 2009
Oxc18a0001 error on my printer. I have a hp photosmart c6180 all in one. How can I fix my printer.
There are several solutions to this problem.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Solution 3 ( conversation with a HP tech):
james cowan: hp error code 0xc18a0001
Earnest: I will assist you in this regard
james cowan: great
Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
james cowan: correct
Earnest: Thank you for confirmation
Earnest: May I have the model number of All-In-One you are using?
james cowan: c6250
Earnest: Thank you for information.
Earnest: James, please let me know the room temperature in which printer is replaced
james cowan: 67 degrees f
Earnest: Okay
Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
james cowan: ok
Earnest: Press and hold the "left arrow" key.
Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
Earnest: Please ignore the above steps, James
james cowan: ok yes nothing seemed to do anything
Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
james cowan: COxxFN0723BR
Earnest: Okay
Earnest: 2. Press and release the right arrow button until the display says "System Configuration Menu
james cowan: ok
Earnest: 3. Press and release the "OK" button.
james cowan: ok and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
james cowan: ok
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Earnest: Let me know once you are done with the above steps
james cowan: ok its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
james cowan: ok
Earnest: Let me know the message displaying on the front panel of the printer
james cowan: printer preparation occurring - do not interrupt
Earnest: Okay
james cowan: ok its done
Earnest: Let us print a self test page from the printer now
james cowan: ok deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
james cowan: ok printing
Earnest: Okay, please check whether all the colors printed perfectly on the test page
james cowan: perfect
Earnest: Great..Cheers!!!
james cowan: thank you very much
Earnest: James, now you can continue using the printer
Earnest: I appreciate your efforts and patience in trying to resolve the issue.
Solution 4:
  • Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
  • Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal". Display should say "Support" and display the FW rev: COxxFN0723BR (or something like that)
  • Press and release the right arrow button until the display says "System Configuration Menu"
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "CANCEL"(Annular) button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 60 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
  • the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occurring - do not interrupt
  • print a test page:
solutions retrieved from here
May 06, 2011 | HP Photosmart C6180 All-In-One InkJet...
HI. i see a oxc18a0001 error in my printer disply .whats mining this error and how i can repair it . please guide me.Tanks a lot.
Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
Solution 1:
Solution 2:
james cowan: great
james cowan: c6250
Earnest: Okay
james cowan: ok
Earnest: Okay
james cowan: ok
james cowan: ok
james cowan: ok
james cowan: printer preparation occuring - do not interrupt
Earnest: Okay
Earnest: Okay, please check whether all the colors pritned perfectly on the test page
Solution 4:
  • Press and release the "CANCEL"(Annuler) button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
  • the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
Feb 07, 2011 | HP Photosmart 8250 InkJet Printer
Hp laserjet p2015 printer showing jam & toner light on
This problem is not initilize the printer. so i change the formater board, now its workinfg fine
Sep 29, 2009 | HP LaserJet P2015 Printer
All alarms lights blinking
OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
James Cowan: OK deal
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
1. We Jam [arrow To the left], afterwards press the button "Adjustment (Setup)", afterwards release - appears the menu "Enter Special Key Combo".
It Is Recommended, but me this did not be necessary: Jam both buttons "Seal photo (Print Photos)" and "Correction to photographies (Red Eye Removal)", afterwards release them. Hereon press and release by turns "Correction to photographies (Red Eye Removal)", "Seal photo (Print Photos)", "Correction to photographies (Red Eye Removal)".
2. Now we press [arrow To the right] until we shall move to point "System Configuration".
3. We Press OK.
4. We Press [arrow To the right] until we shall get to "Hardware failure status: Clear. Press OK to clear". If beside You printer works orderly, that this point in menu not will. It is Important: not to print hereon!
5. We Switch off the printer, include once again.
All, code of the error discarded.
Sep 28, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
How do I reset the ink level indicator on a HP deskjet 4280 using CC640WN black and CC643WN cartridges?
James Cowan: c6250
James Cowan: OK
James Cowan: OK
James Cowan: OK
James Cowan: OK
Earnest: OK
Jul 19, 2009 | Office Equipment & Supplies
Error 79 hp 3300
OK I had the hp error code 79 for HP 3300 problem and here is the conversation I had with the tech...
James Cowan: c6250
James Cowan: OK
James Cowan: OK
James Cowan: OK
James Cowan: OK
Earnest: OK
Apr 24, 2009 | HP Office Equipment & Supplies
HOW DO DELETE FOUND NEW HARDWARE WIZARD
OK I had theHP PHOTOSMART C4400 any error code problem and here is the conversation I had with the tech...
James Cowan: c6250
James Cowan: OK
James Cowan: OK
James Cowan: OK
James Cowan: OK
Earnest: OK
Mar 20, 2009 | HP Office Equipment & Supplies
I have a HP photosmart C7280 all in one, when you scan or copy the page comes out solid black even a scan to the computer scans in black
Test pls a lamp of scaner. Reinstall thedriver. Test a cord. Change a driver. Test the scaner? What does the unit of scaner mooving?
If any help? try this one..................
OK I had the hp photosmart all theerror code problem and here is the conversation I had with the tech...
James Cowan: c6250
James Cowan: OK
James Cowan: OK
James Cowan: OK
James Cowan: OK
Earnest: OK
Mar 15, 2009 | HP Office Equipment & Supplies
60.40 Error Message on HP Laserjet 5025 MFP printer
OK I had the hp error code some problem and here is the conversation I had with the tech...
James Cowan: c6250
James Cowan: OK
James Cowan: OK
James Cowan: OK
James Cowan: OK
Earnest: OK
Feb 22, 2009 | HP Office Equipment & Supplies
Ink System Failure
I just had this problem with a HP C5150 and I found this bit of conversation on the web and it worked for me.
My error code was 0xc18a0501 and the following steps did resolve my issue, hope it helps you as well.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: great
    james cowan: c6250
    Earnest: Okay
    james cowan: ok
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    james cowan: ok
    james cowan: ok
    Earnest: Okay
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
May 26, 2008 | HP Photosmart 3210 Printer
HP LaserJet 3600dn Printer Logo
1,399 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
