Question about Sony Walkman D-EJ360 Personal CD Player
Cd player buttons don't work
I have a Sony Walkman D-EJ360 portable cd player. It was working fine but now every button but play wont work im worndering if its something loose inside or maybe something elce i did or can fix. I've tryed everything but taking it apart thus far. i don't know what to do, any ideas.
  • trmarts Jul 22, 2008
    My Sony Walkman is D-EJ815 and it has the same problem, only the play button works. If I start to play a CD the only way to stop it is to open the player or let it play to the end. The hold button does not seem to work either.
I suggest flipping the "hold" switch, just in case.
Posted on Jul 25, 2007
    President:
  • 3,130 Answers
On almost every port. cd player is a botton lock switch . Some make all the buttons not work and some units only let play work. I suggest you look for this before taking apart as these units have whats called ribbon cable inside them and are very easy to damage them.
Posted on Mar 25, 2006
4 Suggested Answers
SOURCE: Sony Walkman D-NE004
I assume you've tried batteries, cleaned the laser, etc. If so, then the laser might be knackered!
Posted on Mar 20, 2008
SOURCE: sony cd walkman D-EJ100 troubleshooting
There is a switch on the bottom of the unit that puts it in "HOLD" mode. My guess its for use when it is shipped so there will be less chance of damage. Try switching the two position switch to the other position.
Posted on Nov 14, 2009
SOURCE: my sony walkman d-ne320 atrac3plus
On your player there is a switch, usually on the bottom or inside the CD compartment. It will say "hold". You need to switch this in the opposite direction that it is currently in. Afterwards you should have no problems. This feature is designed to lock your player so that you don't accidently push buttons when your active.
Posted on Apr 05, 2011
How to turn it on to play CD?
Personal CD Players usually have a on/off button or sometime a play and stop button. links below,
press the helpful button
Playing portable CD player
Rio Portable MP3 CD Player
Sony Portable DVD player teardown repair
Top 10 Portable Cd Player
Feb 04, 2016 | Audio Players & Recorders
Skips with g protection on
There's only so much ability to cache the data to make up for data loss through movement or vibration. Does it skip while completely motionless?
May 15, 2011 | Sony Walkman D-EJ360 Personal CD Player
How do you set a track to repeat indefinitely?
I can fix this
What is the last thing you did before this problem started?
Bruce
Jan 13, 2011 | Sony Walkman D-EJ360 Personal CD Player
Model D-es51
Try to get it fixed or replaced by the company.
May 20, 2010 | Sony Walkman D-EJ360 Personal CD Player
My Mp3 wont connect to my computer anymore after
Hi, I have got the same issue as you. So take the CD that was delivered with the Sony Walkman and reinstall it in your PC. Then your PC will recognize your Walkman again.
Sep 21, 2009 | Sony Walkman NWZ-S616F MP3 Player
I dont even know
I used the following solution and it worked. The person who provided this solution is very good. THANKS TO THEM! Please read the additional comments at the end too.
noavatar_s.gif AkiraProject
Rank: Apprentice
Rating: 88%, 2 votes
Download the firmware update from sony, burn it to a cd in case ithappens again, or you wanna pass it on. HOLD THE PLAY/PAUSE BUTTON ONTHE WALKMAN BUTTON WHEN PLUGGING IT INTO YOUR COMPUTER'SUSB PORT. WITHOUT LETTING GO OF THE PLAY/PAUSE BUTTON, START THEFIRMWARE INSTALLER & HOLD THE PLAY BUTTON ALL THE WAY THROUGH tocompletion. ET VOILA! YOU SHOULD HAVE A WORKING WALKMAN AGAIN! Yay!!!
OK.. here's what else I did. I followed exactly what is stated above and found I needed to try it a few times, for whatever reason, to get it to "take." Then, the player would still not open properly so I did the above routine AGAIN and this time checked the FORMAT option, which I also had to do a couple times to get that to "take" too. Finally, after working at this for awhile, I was able to install some new music to the player. It is now totally back in working order.
PLEASE: Be patient when you do this. And you can do these routines numerous times if need be with no apparent problem as it just keeps redoing the routine like it was the first time. I was so frustrated in talking with a SONY TECH REP in on-line chat before I came here. I was told the player "had experienced an internal malfunction" which would require service and that there was no was to restore the "system files" to the player, obviously not true as that's what the FIRMWARE (and the FORMAT routine too) upgrade does. Phewww.. I'm elated! take care.
Mar 30, 2009 | Sony Walkman NWZ-B105F MP3 Player
In hold mode
There's a little slider button on the bottom of the cd player. I'd forgotten it was there until I was looking for something else.
Hope it's as simple as this! Good Luck!
Apr 28, 2008 | Sony Walkman D-EJ360 Personal CD Player
Stuck in hold mode
There is a slider button on the bottom of the cd player to take it out of HOLD.
Hope this helps!
Mar 04, 2008 | Sony Walkman D-EJ360 Personal CD Player
Nov 20, 2007 | Sony Walkman D-EJ360 Personal CD Player
Sony Walkman D-EJ360 Personal CD Player Logo
457 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
