Question about Mitsubishi WS-55807 TV
Sound i have a picture but have no sound. is there something in the set up i can check
  • 927 Answers
Good Day;
Try resetting TV by unplugging TV from power source (A/C), for 2 to 5 minutes, then plug back in. Also do same to "BOX" if you are using such device.
If not go into 'Menu' to the Audio area and make sure speakers are "ON".
Good Luck, big IRISH.
Posted on Sep 18, 2008
Sony bravia tv manual
I would check your setting your audio setting see if there is something u need to change in there.
Jan 10, 2014 | Televison & Video
My iphone4 is showing all my pictures and emails as negivtives
Check your accessibility settings on the phone. It sounds like you may have enabled or changed some settings.
Tap Settings > General > Accessibility.
See if maybe something that should not be enabled is.
Hope that helps!
Jul 09, 2012 | Apple iPhone Smartphone
I have picture but no sound. Checked for mute button, increased/decreased volume, unplugged tv and still nothing.
some sets will have an option to turn off the speakers (different from mute); this is used when you want your tv to output to a sound system with external speakers. check your menu settings for something which disables tv speakers--that is probably your issue.
Mar 06, 2011 | Vizio VO320E LCD TV
Alba TV LCD4288DF 1080P Sound but no picture. On switching on get a very brief flash of the picture then screen goes blank, tried on all inputs with same results. It did sort its self out for a while but...
1. Check to see if the TV power outlet has power. Plug a lamp or something small into outlet to test for power. If there is no power in outlet, check your circuit breakers or power fuses.
2. Check to see if you have pressed the power button on the TV or on the remote controls. Check to ensure batteries are placed in remote correctly.
3. Check the setting of the picture brightness or contrast.
4. Check to ensure you have proper cable connections from your source going into your TV.
5. Check the volume settings on the TV.
6. Check to ensure the mute button is not pressed on.
Jan 20, 2011 | Televison & Video
The picture works but the audio sound does not.Could this be due to the set been connected to virgin tv media and the remote has something to do with the problem, is there any manual way to obtain audio on...
first check the speaker setting in the menu see if the speaker is selected ON. if the speaker is on then check the SAP function of the set. check this with the remote with the MTS button on the remote. keep hitting the button untill the word stereo appears.
Jan 19, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have sound but my picture wont show up
Try resetting the video settings on the PS3.
Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings and allow you to set them again.
If by chance you still can't see the picture check that the video leads are connected properly. If you have checked them and still no picture then there could be something wrong with the console itself.
Regards.
Oct 20, 2010 | Sony Playstation 3 (PS3) Console
No sound for cable connection but through dvd,there is sound
Since the set will give sound from a DVD, at least the TV's audio amplifier is working. I'm ready to say you have a bad tuner, but I'm not absolutely certain. There may be trouble in the TV's audio processing stages. Or you could have something set wrong.
First, check the TV settings to be sure you have it set for the right tuning system and that the audio is set for normal. If the settings are right, try tuning in something besides the cable. If you have a VCR with RF output (that is, one that outputs on channel 3 or 4), hook that up and check for normal sound on that channel. If there is still no sound, your TV is at fault and would need service.
Apr 14, 2009 | RCA HD52W58 52" TV
Dark picture but have good sound
You might have a problem in your AV Cables, try buying a new set of AV Cables and see if there is a difference.
If the problem still persist, check your TV it might have something to do with it.
If the problem still persist, check your AV components inside your PS2 it might have damage on its Board.
Aug 01, 2008 | Sony PlayStation 2 (PS2) Console
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WS-55807 TV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
