LG L1753S 17
Problem my screen is waving How can I fix it...
  • 4 Answers
If you keep any magnetic/electro magnetic objects near the monitor these kind of problem may occur, Example Speakers, mobiles.etc.,
But in you case, i hope the problem is with the hardware, Please change the Main Filter capacitor in SMPS of your monitor.
Note: It is not advisable to open the cover of the Monitor. Monitor and TVs stores power even they are disconnected so if you are not sure, please get help from a Service Engineer.
Posted on Sep 10, 2008
LG FLATRON L1753S switching power supply 12dc not working
Plug in the AC ADAPTOR OR CHARGER AND TRY TO SWITCH ON if it runs then your battery is damaged if not then the laptop is damaged
Apr 26, 2014 | Computers & Internet
I have no driver for my lg flatron l1753s monitor, where can i download the driver???
If you want drivers for lg just click this http://members.driverguide.com/driver/detail.php?driverid=983449 then choose the driver you want. Hope it will helps you
Jul 11, 2011 | Computers & Internet
LG Flatron L1753S very bright LCD display how do i remdy this please kindly thank you
You can adjust the brightness with the on screen display controls. This link will get you the manual.
May 02, 2011 | LG Flatron L1750S 17" LCD Monitor
My lg flatron l1753s shows some visual disturbnce like somthing flowing and in few moments shows completely black screen after that normal so......plz tell me what to do to fix it?
It could be the domestic maintenance problem keep your monitor away from moisture and other physical damage it will make your monitor perfect as new working...
Dec 09, 2010 | LG Flatron L1750S 17" LCD Monitor
My computer wouldn't start and it is stuck in power saving mode. its LG flatron L1753S.
check the power cable, make sure you are using the correct video cable and input source and it may help if you try to use a different power cord that is confirmed working. if you use an adapter for it, verify that the adapter is working.
Dec 04, 2010 | LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1753s is not working what will be the reason
90% LCD monitors failures are caused by bad caps.
Please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 18, 2010 | LG Flatron L1750S 17" LCD Monitor
I hold an LG 22inch LCD monitor. I can see waves on my monitor not sure what is causing the waves.. I have moved my speakers to down rack of my comp table.. but still i am getting.. Please help me on how...
may be a problem with your motherboard connector. Try connecting the monitor using another comp and check for the waves. But before this, try to reinstall your display driver.
Feb 24, 2010 | LG Flatron L1710S 17" LCD Monitor
MONITOR WAVE IN LG 700E
Have you tried to increase refresh rate ? Maybe to 80 / 85 Mhz
If that doesn't solve your problem, takit to a Tv technician to desmagnetize your monitor.
Best Regards !
Jun 24, 2009 | LG Studioworks 700S 17" CRT Monitor
How to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
567 people viewed this question
David Payne
David Payne
