This may sound basic and I'm not trying to be a wise guy, but is there any metal objects in the washer, like a pair of jeans with metal buttons? This could be the clicking that you hear.
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
It's noisyMost noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. click the linkhttp://www.repairclinic.com/0088_11_1.asp#Level1_5
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go
through its proper motions. When the lid is closed and the washer has
filled and the agitating cycle begins, you can hear a vibrating noise
as if the plate is trying to move on the gentle cycle, but when the lid
is opened, nothing has moved at all. The drain and spin work fine, and
the machine goes through an entire cycle without error messages, but
the clothes aren't clean. You said, you have heard a lot of horror stories of how
expensive these washers are to repair, so would like an idea of what's
wrong beforehand. Here are a list of common vibration noises
Noisy, vibrating, off-balance Is the washer level? Does the washer rock when pushed against the corners? The washer must be level. The front and rear feet must be in firm contact with the floor. Check that the locknuts are tightened. See “Level the Washer.” Is the floor flexing, sagging or not level? Flooring that flexes or is uneven can contribute to noise and vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under the washer will reduce the sounds. See “Location Requirements.” Is the load balanced? Evenly distribute the load in the washer basket and make sure the height of the load does not exceed the top row of basket holes. See “Starting Your Washer.” Do you hear clicking or other noises when the cycle changes from washing to draining or spinning? When the drive system shifts or the washer basket settles between cycles you may hear noises that are different from your previous washer. These are normal washer noises. Is the washer gurgling or humming?
Is the washer level? The wash load should be balanced and not overloaded. The washer must be level. The front feet should be properly installed and the nuts tightened. Reset the rear leveling legs (if needed). See the Installation Instructions. Did you completely remove the yellow shipping strap with cotter pins? See the Installation Instructions. • Are the gears engaging after the drain and before spin, or is the upper part of agitator clicking during wash? These are normal washer noises.
Let me know if any of these are the solution! Huuum
