Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Garmin nuvi 360
I have a brand new nuvi 360. I was charging it for the very first time and my son knocked it off the mantel. It wont come on at all. Is it worth fixing and if it is, where should I send it?
cindy
  • Garmin Master
  • 2,130 Answers
Have you tried pushing the reset button on the back under the antenna?
Try turning it on and listen for any sound, like the start up beep. Do you hear any sound at all after 30 seconds?
There's a couple possibilities that could have happened.
1. The screen and/or main board has been damaged.
2. The screen cable has come loose from the main board.
If the unit is under warranty (registered with Garmin) you can call them and see if they will fix it for you. They may charge you if they determine it was dropped or mishandled. www.garmin.com
If you have problems with getting them to fix it for you, I'll be happy to look at it for you and give you a quote. I have repaired many Nuvi's and I have references.
If interested, please email me at ks3r at sharc dot net.
- Jim
Posted on Sep 10, 2008
  • SHARCNET-USA
    SHARCNET-USA Sep 12, 2008
    Cindy,
    I am glad you got it working again through our emails. Could you please rate my solution please?
    Thanks,
    - Jim
Garmin nuvi 2595 will not take a charge
I found my brand new nuvi 2595lmt repeatedly power cycling and loosing its charge when I tried to charge it (for the second time as well). I was using a different USB cable. When I switched to the supplied cable with the "Garmin" insignia on it, the problem resolved. Hope that helps, good luck.
Feb 17, 2012 | Garmin GPS
My son bought this for me, and he has taken the user manual (if there was one) to New Zealand with him - he lives there. Can I obtain another manual? I don't know a) how to charge the battery and b)...
Here is your Owner's Manual:
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
To Charge Your Nuvi:
  • Connect the vehicle power cable to the mini-USB connector on your nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for the nuvi to charge.
  • Connect an AC adapter (optional accessory) to the nuvi and a wall outlet.
  • Connect your nuvi to a computer using a USB cable. The USB cable is included with some Nuvi packages. The computer must be on for the nuvi to charge.
Mar 11, 2011 | Garmin Nuvi 265W GPS Receiver
Brand new Garmin 1300. Husband now travelling, un...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Cracked screen repair cost?
the repair cost will be almost as much as a new GPS, around $200
Nov 25, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi 360 needs CA maps Anywhere for no
There are topo maps for the US for free from this site. We are not affiliated with them, the link is provided as a courtesy only.
http://www.ibycus.com/ibycususa/
Jun 15, 2009 | Garmin NUVI 360 GPS Receiver
Garmin nuvi 360 can't read sd card
Make sure you format first the sd card and then the maximum giga byte is 2 mb and the minimum is 16 mb.
Jun 09, 2009 | Garmin NUVI 360 GPS Receiver
Garmin nuvi 360 wont unlock maps
Master reset is after you turn on the GPS put a finger on the left lower corner rightaway and then keep the finger there, wait until it shows up the "Do you really want to start up in maintainance mode"
You are not able to use others nuvi's map on your nuvi 360, as each map must match with the GPS unit ID, to find out your GPS's unit ID, go to "Setting" tab on "System", tab on " About"
Mar 29, 2009 | Garmin NUVI 360 GPS Receiver
I have a garmin 265w that shut off by itself and will not turn o
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I can help you reset and fix your Garmin Nuvi 265W.
There are three steps to take to get your Nuvi 265W running like new:
I hope that helps.
Nuvi 265W Manuals here.
Feb 02, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
My Garmin Nuvi 360 lost satellites during use and can't locate
I had the same problem with mine...I shut it down and left it off while giving it a full charge...
Jan 14, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
GPS Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
