Question about Refrigerators
ICE MAKER THE ICE MAKER WILL NOT FUNCTION AT ALL
  • 76 Answers
Tell me more about what the problem is,does it not come on or does it not make ice?
I can help but you sould be presice on things like this....
Waiting for your reply...
Posted on Sep 09, 2008
Samsung rs257 ice maker not working. We already reset ice maker and checked water line to ice maker. We also used dryer to defrost bearing on ice maker. Still not working.
Hi!
The manual provides a number of reasons why the ice maker doesn't work:
Ice is not dispensed
Did you stop the ice making function?
Is there any ice in the ice storage unit?
Is the water line connected and the shut-off valve
open?
Is the freezer temperature too warm?
(Set the temperature lower)
Did you wait for 12 hours after installation of the
water supply line before making ice?
I'm adding a link to the manual:
http://manualsbrain.com/en/manuals/948215/?page=29
Jul 21, 2017 | Samsung Refrigerators
We have a U-Line mini fridge with ice maker. 1 month old and 1 week ago it started making "working too hard" noises. 1 week ago we had paused the ice making function. Related ?
ICE CUBES IN ICE MAKER HAVE LIKLEY SHRUNK
AND ARE NOW JAMMED IN ICE MAKER INSTEAD OF FALLING OUT
CHECK THE ICE MAKER FOR JAMMED CUBE
Jul 20, 2017 | U-Line Refrigerators
Youtube
Ice maker is not going to harvest mode.
a) Either Ice maker is faulty. Change Ice maker.
b) Before that make sure that freezer compartment has reached minimum temparature for the ice maker to function properly. Normally it is - 11 c or lower. You have a freezer temperature like -18c and not harvesting then problem is on icemaker. Sometime you can pull the power out from ice maker unit and plug back after couple of minutes to reset the ice maker unit control board. It might work again.
Sep 04, 2014 | Whirlpool Refrigerators
Water dispenses from frig but ice maker is not producing any ice. We've adjusted the temp up and down and it isn't doing any good. Any suggestions on what else to check?
Before you adjusted the temps, were you having cooling issues? If you were, those cooling issues would need to be resolved in order for your ice maker to function properly.
If you had no cooling issues, the first thing i always ask is when did you last change your water filter, assuming you have one. If you dont have one or it was changed recently, then do the following. Turn the ice maker off for at least one hour, then watch to see if it begins to cycle, the angled row of teeth will rotate. Some models will not operate if the door is open, so close the door light switch while you observe the ice maker. If the ice maker cycles, but gets no water, the ice maker solenoid valve will need to be replaced. If the valve needs to be replaced, you may sometimes find the fill tube that directs water into the ice maker is frozen with ice, this will have to be cleared manually for proper function. If the ice maker does not cycle when you turn it on, you have a bad ice maker or there is a wiring problem with your ice maker system.
Oct 01, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Water is not going into icemaker
Their are 2 possible things wrong. The water valve or the ice maker. Nothing else in the ice box determines water fill but the ice maker itself. Since the water valve needs to be replaced when you buy another ice maker( their is no way to repair an electronic ice maker) I say replace the water valve first and see if the ice maker starts working. Then if you have to get a new ice maker you already have a new water valve. First before you do anything stick a thermometer in the freezer and verify the temp is below 25F. An ice maker will not function if the temp is over 25F in the freezer.
Jun 07, 2010 | Hotpoint HSS25GDMWW Side by Side...
The arm on the ice cube maker is broken.
how to replace water dispensing paddle on a side by side
Apr 06, 2009 | Refrigerators
Ice maker water line appears to be frozen on gd5sha. ice maker won't function.
thaw the whole refrigerator for a whole day to thaw the ice inside the water line. it will reset also the timing of the ice maker.
Jul 05, 2008 | Whirlpool Refrigerators
Ice maker
reach your hand into ice maker assy, is there ice in it and not ejecting??? there are tines that eject the ice, do these move around freely and easily(if so you need a new ice maker they should not turn by hand)
Feb 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
