Question about Canon imageRUNNER 210S Copier
Error "E005" by Canon GP285
I have a problem with a Canon GP285, but I can't find a forum for this, so i post here... sorry for this.
Does anybody know how to solve the Error "E005". The manuall tells me to take power from the copier and turn him on again after 10 seconds. But that's not working. So help me please...
Thank's in advance,
Matthias
  • Canon Expert
  • 1,326 Answers
A E005 is the Cleaning Web has run out or the counter has reached it out count. You have to replace the cleaning web in the fixing unit. And reset the counter for the web. It is not good to just reset the counter because inf you run out of the cleaning web you may cause more damage to the fixing unit and thus coast you more money and time. It's best to call a repair person and ask them to bring a cleaning web ( maybe $65.00 -$75.00 plus labor) That's your best bet
Posted on Sep 10, 2008
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
Sep 14, 2009 | Office Equipment & Supplies
Canon CLC800 error E005, How do I reset?
I have the same difficulties
please help me if you got solution
my E mail is:mabdi6325@gmail.com
Jul 11, 2009 | Office Equipment & Supplies
E005
Hi Malcom
Go in servicemode(use a long L&key to press the microswitch)
You will find the microswitch by openning the front cover and on the left upper part under the controll panel you will see a very small hole were you have to insert a long,thin L&key to press the microswitch.
If you have pressed the switch a "$" sign will apear on the screen.Press *6* and page to the web counter,press clear and then ok.
After this is done press *4* and page to error press ok and switch machine on and off.
That should do it
Jan 16, 2009 | Canon NP 6050 Copier
Davor skopje
sorry for my bad english but, this is an answer:
your problem refered to a cleaning web, of the upper fuser roller, check this web and you can see, its finish, if you havent this, you can turn arround, but observe vary well his position, then
after of remplacement, you have reset de web alarm,
when you relocate all that pieces in her order, turn on the copier, then after this send the error code, push the buttons in this secuence...
( * ) ( 2 and 8) thogether ( * ) to enter service mode
then push ( func )
after push ( fuser )
after push ( E005-RLS )
and then turn off and turn on the copier and ready, thats all
if not work, check your sensor web position and repeat the E005-rls procedure
for more info, you can obtain the clc5000 service manual to download in www.yoreparo.com forum,
or send me an email, can i help you, good luck, budy.
Dec 20, 2007 | Canon CLC 1000 Color Copier
CANON GP 335 E005 problem
We have fiqured out that the cleaning web needs to be changed therefore we have successfully done this but the error code E005 still appears.
Oct 04, 2007 | Office Equipment & Supplies
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 210S Copier Logo
316 people viewed this question
old marine
old marine
