Question about Whirlpool Washing Machines
Keep getting error codes such as LD - Whirlpool Washing Machines
    Genius:
  • 1,028 Answers
Ld is long drain must be a calypso .. lean washer back remove bottom panel if pump has bottom screws remove and clean pump if not is probably older version ..thet were bad for having stripped drive splines only fix was to replace entire pump
Posted on Sep 09, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Keep getting error code Ld what does this mean
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by the control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for proper pumping.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Post your model number I might have a service manual and a better answer for you.
Jun 22, 2011 | Washing Machines
I keep getting ld error
long drain error code. replace ur pump with the upgraded version. or unclogg the pump if u have the latest one
Feb 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
THE MACHINE KEEP ON DISPLAYING THE CODE SC0322 (COPIER RICOH AFICIO 1045 MODEL). HOW TO FIX THAT PLZ?
Ld unit problem. This code can be very frustrating, as it can be triggered by several things -top right door switches shorting out, toner on the LD unit board, laser synch board problem, bad connection between the BICU and the LD unit, etc.
The bottom line is, if you're not a technician, you will need one to solve this error.
Make sure to always perform the LD pitch adjustment (both 400 and 600dpi) after doing any service to the laser unit.
May 18, 2009 | Ricoh Aficio 1035 Copier
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
I have a cabrio washer and keep getting LD error code, washer looks to drain fine but won't advance on to spin cycle - sits there for a few minutes trying to drain even though no more water is in tube,...
Friend,
ngfam1 At your service!
When it is a code the machine is telling you that there is a fault and the electronic system needs to be diagnosed by a trained tech.
My advise is,
You spent enough money buying that Cabrio to be experimenting and guessing and buying expensive parts for it!
Let the tech fix it 123 and your done. It may not have needed the drain pump and now that money could have covered the service call!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
Washing Machines Logo
558 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
