Question about Toastess TT-200 Turnover Toaster
TT 200 Toastess Toaster
After 1 1/2 years the element broke - the comany was sold and the nw company only uses the "Toastess " name - this model belonged to previous owners the newer model is identical but has a slightly different code. Ques 1: Is there a way to solder or repair a broken element. Ques 2: if so can this be done at home? How? Ques 3 : If not is it worth taking it to a repair shop? Thank you
  • Dee Albert Mar 30, 2006
    Thank you Windman - we have all the requirements you mention to fix it however can you provide step by step directions of how to do it?? Much appreciated DTA
  • 4 Answers
When I was a kid we had this sort of problem with a toaster - and an old electric space heater. We just TIED the ends of the element together (where it broke) and it worked fine. No tricky soldering or anything. And they lasted for Years!
Posted on Jun 30, 2008
    Champion:
  • 277 Answers
Hi 1)yes - aluminum: solder, plastis: epoxy 2)yes if you got special gear for it 3) NO BUY A NEW 1 IT WILL COST HALF THE PRICE!! GOOD LUCK
Posted on Mar 26, 2006
Heating element
there is a number on the heating element, the model of your toaster oven should be on the backside of the unit itself, armed with this info, you should be able to find a replacement element
Jul 28, 2013 | Cook's Essentials Cooks Essentials Arome...
Toastess -TT 215P 2 slice toaster
if you can open it up the thing that holds the tab down could have been used up already.
tnx 4 using fixya.
drcool
Sep 09, 2008 | Toastess TT-215P 2-Slice Toaster
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
Bottom elements on DeLonghi AD699 failed.
Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
I have a old wall built in thermador toaster & need parts
I have a Thermador built-in toaster ( new in box). It has never been used but I have had it for many years. Willing to sell.
Mar 29, 2009 | Kitchen Appliances - Others
Wanting to buy a toaster
Did you try Wal-Mart... or a good hardware store? They were selling this kind of toaster just a few years ago because it was some kind of anniversary. I have a new one and one that's over 30 years old (and that's pretty good for a small appliance!)
Dec 23, 2007 | Toastess TT-200 Turnover Toaster
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Another problem comes up....
You definitely have a problem with the hold down circuit. You will need a DMM. If you don't have one they are fairly inexpensive now and with a little reading of the instructions you should be able to master their use. Look for a fusible resistor. It should be a small shiny canister, pointed on one end flat on the other, with metal leads on each end and inline on the wire to the hold down mechanism. Once you find this, with the DMM on resistance setting (continuity), check across the device. If the DMM says infinity, in other words it shows a 1 and the display never changes, this is your problem. Replace it with a new one. They protect the device from runaway heating and are set to open at predetermined temps. Replace it witht the same rated device. Available at most electronic stores. The rating should be in centigrade (such as 160, 180, ect). This should solve your problem. You cannot solder the thermal fuse in as solder will melt when the toaster gets hot. It must be crimped to the wire. Sounds like your almost there. Good luck.
Jul 20, 2006 | Toastess TT-415P 4-Slice Toaster
The level of the toaster doesn't lock
I doubt if you can fix this without taking the unit apart. Usually it is not that difficult to remove the cover. Unplug the unit. Turn the toaster upside down and remove the screws holding the outside case on. The case usually slides off or by springing the bottom of the sides out you should be able to remove it. Once the cover is off it should be easy and obvious to fix the problem you described. When you have the unit secured reverse the order to assemble the unit and you should be back in business. Good luck.
Jul 17, 2006 | Toastess TT-415P 4-Slice Toaster
Toastess TT-200 Turnover Toaster Logo
230 people viewed this question
Top Toastess Kitchen Appliances - Others Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Toastess Kitchen Appliances - Other Expert? Answer questions, earn points and help others
