Question about Microwave Ovens
Need microwave turntable
I need a turntable & support ring for a Goldstar MV1310w.
  • 76 Answers
You would have to order it, Phone Tecsa in Bloemfontein and ask for Jacques.
Give him the name and model num and tell him Wouter from Masters told you to Phone him.
The num is 051 403 5280
Good luck...
Posted on Sep 09, 2008
MV1310W .....blower fan and both lights are inoperable. The oven itself does heat.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you prefer, you can order a new control circuit board from one of various suppliers. Look for a part number stenciled on the board, something like 6871W2S143B or 6871W2S008D, etc.
You can order it from the Pros here, from the Sears Parts Direct Web site image-4235112-10659157 or from Encompass here.
Jan 17, 2011 | Goldstar MV-1310W/B Microwave Oven
We have a Goldstar mv1310w microwave that the lights have quit working on. This is the light over the range that you can turn on while cooking on the stove. We put new bulbs in and I even show voltage on...
mcdevito75 here, It could be the light sockets are dirty from cooking fumes, oil etc, remove power from the sockets and clean them with alcholol and cotton swabs or paper towels etc.
Jun 28, 2010 | Goldstar MV-1310W/B Microwave Oven
Goldstar Microwave turntable does not work.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can also do that to attach AC voltmeter leads to the leads of the motor. Then run the microwave to see if it has voltage present.
If so, you have a bad motor.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
You'll probably have to call them to find parts for your model.
(If yours is not an LG/Goldstar, please reply back with your brand and model number so we can help you)
If you don;t see the voltage, then you most likely have a problem with the control panel.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 11, 2008 | Goldstar Over-the-Range Microwave
Goldstar 1310W built in
The following parts are in the turntable system: The turntable motor, underneath the floor of the microwave; the turntable coupler, which is like a small plastic piece; the turntable support, either a three-legged or circular piece with wheels; and the glass turntable tray.
It sounds like maybe your turntable support is missing?
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. Goldstar owner manuals can be downloaded here.
Aug 11, 2008 | Goldstar Microwave Ovens
Non rotating lg turntable fixit try failure
Looks this model's turntable support has a coupler shaft built-in which is supposed to go down into the turntable motor hole and make contact with the turntable shaft. Is that right in your case?
So I would wonder if the turntable support has gotten bent due to heat. That's common on some models.
When you take it out and look at it from the side, are the legs straight and perpendicular to the shaft or are they bent down?
On some models, you can heat them over a stove flame, then put them on a flat surface with a weight to old them in position while they cool.
Otherwise, you'll need a new turntable support. LG / Goldstar calls this a "rotating ring".
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | LG LRM1250 Microwave Oven
Lg lrm 1250
I need a new ring that goes underneath the glass turntable.
That would be part # 5889W2A005J "ROTATING RING ASSEMBLY"
To order parts or for other Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
William E. Miller, AS-EET
prototech@usa.net
Apr 27, 2008 | Microwave Ovens
Looking for a glass turntable plate model #MQS1236H
That is part # A06014000AP and you can get it here or here.
Apr 24, 2008 | Goldstar MV-1526 Microwave Oven
Microwave oven is noisy during use
Sounds like you have a failing turntable motor. You can contact LG / Goldstar about parts or service at 800-222-6457.
Apr 07, 2007 | Goldstar MA-790W Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
