Question about Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD 4005 Recorder
Trouble: C-104 & C-206 I read one of your replies and you stated that the unit may be an old one. My unit was built in 2003 and I have only recorded one DVD when it was new. It plays well but will not record in DVD. Is it because I am using new discs.
rcoache@charater.net
I've had this problem myself and a list of others. FYI, I've found it easier to use dvd-rw discs
for any mistakes you might make. Use Video mode (not VR mode) if you want to watch them
on a Computer or other DVD again and you have to Finalize disc. As for your problem, if all
else is okay, try removing your disc and unplugging the unit. I've done this numerous times
for odd reasons something wasn't working right. I'm not sure how long you have to keep it
unplugged. Try 10 minutes and you'll have to wait 30 minutes or more if you want the clock
to sync up on its own but you can set the clock manually. I've done this for a blinking
REC light in the VCR mode after trying the TIMER REC button.(it shouldn't be blinking
when the unit's working properly) This gets to be a pain and I've had to do this sometimes
2 days later or 6 months later. It's not a perfect unit. By the way, if times an issue, reset the
clock manually as soon as it starts blinking. This will cut your reset down to 11-12 minutes.
Hope this helps.
Posted on Sep 12, 2008
Can I use a bamix from usa 110volt in Europe 240v ? can bamix classic accept both voltage or I need a transformer 240v to 110volt
This product is intended for use in the United States and Canada and is built to United States electrical standards.
  • Made in Switzerland.
  • Apr 03, 2017 | Audio Players & Recorders
    Just bought a second hand one trying it out it doesn't play with my discs which are recorded x4
    Obertelli, I am in the United States but would still appreciate your old player. You can send me an email at wb7ptr@aol.com. This is the email I use for more general online use.
    Lynn
    Dec 03, 2015 | Sony Audio Players & Recorders
    TV/VCR Recording of TV Programs Using a Digital Converter Box
    Hi Rick
    I think you are painting yourself into a corner. So to Speak.
    Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
    The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
    I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
    Here are the unit features
    1. Main Features:
      DVB-T Twin Digital Turners
      DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
      2.5" Sata Hard disk: 500GB
      Time Shift Function (Pause live TV)
      HDMI Digital Output
      Digital Audio Output
      CVBS/YPbPr/SPDIF connectors
      Supports TV formats 4:3 and 16:9
      Electronic Program Guide (EPG) up to 7 days in advance
      EPG searching and auto download
      Recorded program edit
      Parental Control
      Copy files from internal HDD to external HDD
      Built-in WiFi
      Network Playback
      USB 2.0 Interface
    Now
    This was my original reply until I saw the light.
    So, Hopefully one of these will answer your queerie.
    A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
    With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
    If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
    Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
    HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
    It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
    Cheers.... Trevor
    Was this Helpful
    .......Then give me a tick of approval
    Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
    Re: Samsung Printer CLX3175FN -- receiving message "Replace imaging unit soon." I've read other expert replies but am still missing some information. Can I replace the unit myself? How do I do...
    Nancy, Your imaging unit has a limited lifecycle. Documentation states that it can make 24,000 B&W pages and 6,000 color. The message is telling you that you are getting close to that limit. Eventually you printer will stop printing, and your messahe will state "Replace imaging unit". This can be done by you. It is very easy to do. The imaging unit is fairly expensive: around $150 or more depending on the merchant and shipping charges.
    Drew
    Feb 16, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
    What does TOC read mean, the cd does not spin
    TOC stands for Table of Contents. On a MiniDisc recorder or CD recorder, a Table Of Contents MUST be written before a disc is usable. On A player, a TOC must be read before the unit knows where to find the songs. Sounds like the laser is NOT reading the TOC, so you will hear nothing until that is corrected (clean lens or replace unit). Try a storebought CD, as perhaps is doesn't like your own burned CD's and most units built before 2000 will not read your own CD's that you make.
    Jan 07, 2011 | Emerson MS3103 Shelf System
    Disc reading display
    Have you tryed to clean it wit a lens cleaner. Sounds like just needs a good cleaning.
    Hope this helps you
    Jan 12, 2010 | Philips DVDR75 DVD Recorder
    Manual for sansui vrdvd 4005 and remote
    I believe it's available on a Sears sponsered website called managemylife.com. I hope this helps you. There's also info about getting parts (remote).
    Dec 23, 2009 | Sansui VRDVD4005 DVD Player/VCR
    2003 Toyota Corolla - Odometer stopped working yesterday when it hit 299,999 kms's- could this be a fuse issue?
    It appears to be a known limitation…
    Nicole Grant of Toyota Canada public relations replies:
    “Toyota has become aware that on 2003-2008 model-year Corolla and Matrix vehicles, odometer mileage is recorded accurately only up to 299,999 km. A new odometer must then be installed.
    Our dealerships record mileage and service dates when an odometer is replaced. A copy of these records is placed in the owner's manual, along with a sticker on the odometer indicating that it was replaced.
    Should a used-car buyer have any questions concerning the odometer reading, they may contact Toyota Canada or inquire at the motor vehicle office in the province where the vehicle was originally sold.”
    A: Mohamed Bouchama, executive director of Car Help Canada (www.carhelpcanada.com; 416-651-0555), a non-profit consumer advocacy group, replies:
    “Toyota should be responsible for the total cost of the repairs. It should "do the right thing by consumers" and recall every vehicle that has this problem due to their factory defective part.”
    Nov 27, 2009 | 2003 Toyota Camry
    Sansui VRDVD4005 DVD Player/VCR Logo
    119 people viewed this question
    Top Sansui Televison & Video Experts
    matt martin
    matt martin
    Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
