Question about Philips Televison & Video
External Tuner Device for VCR/DVD player
How do I find an external tuner device so that I can copy from my TV to VCR tapes? Manual says that is what I need.
I can play VCR tapes and DVDs.
Philips Digital Video Disc Player & Video Cassette Recorder
Model # DVP3345V/17
cr2003@bellsouth.net
  • 752 Answers
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Posted on Sep 09, 2008
  • cosgrcos Aug 14, 2011
    (sorry about the spelling) the older vcr's are not digitally compatible, you can get ch 6, but not ch 6.2 (in my expeirence)
    0
You can hook up a converter box to your old VCR. You won't be able to program but you can record. If you want to program you can use one of the newer recorders that doesn't have a tuner and use the old vcr and converter as a tuner.
Posted on Oct 11, 2010
No sound on the tv
As TV and DVD playing reproduces sound, you have to check TVs tuner function first. Connect the TV to external areal by connecting areal via areal socket. Make an auto-tune function. Refer the user manual about how to make an auto-tune to local on-air program. Make sure that, the TV reproduces picture and sound normally. If it is correct, your TV is perfect in all respect. If not, the tuner to your TV should be replaced with same type and number.
Jun 20, 2012 | RCA Universal Remote 3 Device Remote...
We have a Samsung Smart TV. We cannot get the signal and have installed a Digital Satellite Receiver. We have a Magnavox VCR and a sony DVD Player. We owuld like to attache the same to our TV and watch...
Depending on your Satellite receiver's output type (i.e. HDMI or Component - Red, Green, Blue) you should connect to your tv's appropriate external inputs. Example: if you choose to connect the receiver via HDMI, then you use the SOURCE button on your tv and select the correct HDMI input you have connected your device to. If connected by Component (Red, Green, Blue) then use the SOURCE button to select the correct Component input, and so on.
Note: HDMI is the best connection type - you won't be able to access your receiver from the tv's built in tuner.
As above explanation, your VCR and DVD devices should be connected to your tv in the same manner - unless it is a combo unit (VCR & DVD in one), in which case this device can be tuned into your chosen tv channel (via the tv's tuner).
Note: if you have one of the latest SMART tv's, it should already have a built-in "Hi Definition" tuner which will allow you to watch free digital tv broadcast (DVB).
Hope this helps...
"Please rate this solution"
Aug 28, 2011 | Samsung Televison & Video
How do you find a dvd recorder that does not need and external tuner? Does the new tv's have a tuner that you can use with the current dvd recorders
U have cables or satallites tvs services hook up.U can record VHS tapes and used any DVD/VCR recorder machines hook up.Because the pay services does convert the signal back to analoge tv signal so u can record VHS tapes.
May 12, 2011 | Toshiba DVR620 DVD Recorder/VCR
No signal when turned on
There is a plain screen only in your TV we things. If so tuner of your tv has damaged. It should be replaced with an identical type. To ensure that the the suspected item is tuner, give your tv an external video from any source like dvd player;VCR, CD player if there is an audio video input sockets exists in your tv, and switch the tv in AV mode with remote control.
If the video of the external source is Ok, surely the tuner is the suspected one. Replacing it will solve the problem.
Oct 16, 2010 | RCA TruFlat 27F520T 27" TV
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Recording TV shows
Since it doesn't have a tuner, it will not be able to store channels - it will only record the channel that your cable or sat box is on currently
Aug 19, 2008 | Philips Magnavox DVD/VCR Dual Player
External tuner
if it's possible attach a free-view box to it.
Jul 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd/vcr combo
I'l make sure, but I beleave L1 and L2 are inputs. You need to select the one where the show comes from, Its it coming from the L1 connector or L2.
Your device doesn't have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
Il confirm this and reply to you in a moment.
May 18, 2008 | Televison & Video
Televison & Video Logo
1,507 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
