Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
DVD Player won't read
The DVD player won't read the DVD's. It started a while ago just not reading some and reading others. Now it won't read any & probably just needs the laser cleaned. I just would like to know which screws to remove to get at the inside chassis.
  • 4 more comments
  • Dan Caldararo Mar 30, 2006
    Could you please go into a little more detail about encoding for the right region? Most of the DVDs are coming from Netflix.
  • ricardo m Nov 06, 2007
    it plays for awhile.then freezes at the same spot everytime.mostly on dvds of tv series.?is it just dust?
  • Kim B Feb 03, 2008
    My DVD player has not worked since I bought it! I'm wondering if it even has a real DVD player inside. If anyone has advice on getting DVDs to play please let me know.
    Thank you
    Stuck!
  • Anonymous Apr 01, 2008
    Mine seems to read only certain DVD's......while others it says no disc.....what a piece of **** this set .....are there any drive adjustments?
  • Anonymous Apr 26, 2008
    My Aiwa VX-F20DV1u combo worked fine at first (appx year 2000) then I started playing home burned DVDs and it would play these and stopped playing manufacturer original discs (blockbuster rentals) and now won't read any disc at all.
  • headache1 Jun 19, 2008
    My Sharp DVRW 360H has recently stopped recording.As soon as you press the recording button then it starts and then almost emmediately stops and starts loading up.Or it will seem to record for housrs and hours and then you find out afterwards that it has not recorded anything at all.I have tried cleaning it with a DVD lense cleaner quite a few times with no luck.Can you shed some light on this?
  • 513 Answers
I have to disagree with the previous answer you got. It's a common scenario that someone uses his DVD player to play CD's and then the point is lost. DVD players DO get plagued with dusty lenses, same as any other disc player. If you can get to the lens its worth a try, but from your post it seems that you should take it to a pro lab. I say this because you'll have to open the TV chasis to get there, and TV's are just about the most dangerous home appliance to mess with. Touch the wrong spot, even when plugged out, and you can get bit by enough voltages to kill. Take care and good luck
Posted on May 02, 2006
  • 30 Answers
It is very rare to have any problems related to dirty lenses, on DVD players. This is because the rotational speed of the disc is so high compared to CD, that a significant drag wind builds up under the disc, which keeps the lens blown clean of dust deposits. Your laser might be defective though. Also, make sure that the DVDs are encoded for the right region.
Posted on Mar 27, 2006
    New Friend:
Can anyone give a response that let's the person actually open and try to fix it. Not just tell them not to and to take it to get repaired... If they wanted to do that, they wouldn't have written on here
Posted on Dec 11, 2012
There is something that you can do safely and it'll cost you just a few dollars, just go to any electronic store(Kmart, circuit city, office depot, best buy etc.) and buy a dvd laser lens cleaner and that might solve your problem. This way you don't have to open the TV chassis.
Posted on Apr 16, 2007
3 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: Sharp vt 2128m
You didn't say whether the unit was shutting down. Usually when there is a fault in the VCR the TV shuts down to protect the unit. Your unit has a fault in the tape system. It has a bad sensor or something in it which is triggering a fault. Sometimes kids put things in the slot and cause this kind of problem. Using a flashlight look into the slot and see if there is an obstruction. If there is try to get it out. If you are capable and understand TV safety, unplug the set and remove the back to look for any foreign objects in the set. If there are no foreign objects you will probably have to have the set looked at by a shop if you want the VCR to work. If you have composite video and audio inputs on the unit you can hook up an external DVD player with an RCA patch cable. Hook the same colors together on each unit. Yellow for video, red and white for audio. You will have to select the input through the menu. Good luck.
Posted on Jul 12, 2006
ekcnoel
  • 998 Answers
SOURCE: I have a dvd player built into my tv and until a
The problem of dvd is the optical lens it's just dirty, first try to use a cd cleaner if doesn't work you should do it manually. Unplug your unit first then try to remove the cover of your unit but be sure to remember all the parts location, then you should use a cotton buds then wipe the optical lens very gently but be sure not to touch your optical lens. this may help you thank's.
Posted on Jul 11, 2011
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
My dvd gaves me a bad disc
when you play nothing but bootlegs in a dvd player, they tend to burn out the eye inside the player to where it will only read bootlegs. the original movies capabilities won't work anymore. hope this is a help to you my friend.
Jun 21, 2012 | Cyberhome CH-DVD 300 DVD Player
Dvd player reads no disk..even though the disk is in player, i want to watch the dvd i rented now. help
Some rented discs won't play becauses of scratches and dirt, if other DVD 'S work it is not your player, but if all won't play try a DVD cleaning kit and follow instructions.
Mar 17, 2012 | Sony Televison & Video
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
I put in a dvd, it starts to read it, and in a couple of seconds it ejects
Hello; There are many laws and rules controlling what you can watch on all DVD players, built into a TV or separate player. If you go buy an MGM or other dvd of some movie at Walmart , Best Buy ETC it should play in your DVD player, But if You or somebody " Burned a DVD" , It Likely won't play. If The DVD is an original store copy and still won't play, the DVD chassis must be replaced. BIG BUCKS. Just buy a Cheap DVD player and plug into the jacks on the back of the TV and save a TON of money. John
Jun 27, 2011 | Emerson LD195EM8 19 in. LCD TV
My Panasonic DMP-BD655 won't read any discs. I was fine a month ago but hen it wouldn't read Blu-Ray discs, but would still play DVD's. It stopped playing DVD's about 3 days ago. I have upgraded the...
Ive only had mine for 2 months and it just stopped playing dvds all together. I had a brand new dvd playing, went to switch it to another new dvd movie and it wouldnt read it or any other dvd Ive tried. I havent tried a blu ray disc yet.
Jan 02, 2011 | Panasonic DMP-BD30K Blu-Ray Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Jvc xv m-567 won' t read cd or dvd
The problem, ended up being the DVD drive motor. Unfortunately, it wasn't worth finding a replacement motor.
Jul 10, 2008 | JVC XV-M567 DVD Player
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
8,603 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
