Question about Fisher and Paykel GWL11 Top Load Washer
Need to set the washing machine for hot cycle, cold rinse
Need to set the washing machine for hot cycle, with cold rinse and it is not letting me do it. The default goes to warm water!!! Tried setting the option for my own favorites, does not work!
  • 1 more comment
  • CrazyBooBoo Oct 06, 2008
    Did this and it still does not let me select Hot with a cold water rinse...
  • Anonymous Oct 09, 2008
    Our Ecosmart washer won't let us hot soak. It defaults to warm (as an energy saving feature). We have successfully used the "favorite" program in order to get hot water for a normal wash cycle. If anyone knows how to trick the washer into letting you hot soak, let us know. Thanks.
  • Anonymous Mar 14, 2014
    thinking it may be the valve. do you think the computer will need to be reset after we replace the part? I will set it on cold and it will try to switch to medium or hot in mid cycle. The hot water isn't on because the machine keeps it running.
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Posted on Sep 13, 2008
I have set the rinse cycle set to cold on our washing machine, however the clothes are rinsed hot, when I take the clothes out of the washing machine after the cycle is complete they are hot. How do I...
the hoses may be reversed...select cold rinse and turn on washer...if its hot..then try cold wash, is it hot? then try hot wash...is it cold? if so, check your hoses are on correctly....reverse hose's
Jan 23, 2011 | Kenmore Washing Machines
I have centrex washing machine 4.5 kg, the problem is it stops after washing. it doesnt rinsing the clothes stops at this point.
It could be that the cold inlet valve is faulty.. Your machine will rinse with cold water only and if the inlet is faulty then it won't fill for the rinse cycle. This also means that the wash cycle, if set on 'warm' is only getting hot water. Set the wash temp to cold and see if the machine will fill. If not, the cold inlet valve is the problem. You'll need to replace the inlet valve which may be a double unit with two hose connections Best to call a tech..Good luck Nomess (Please take a moment to rate this answer)
Jul 18, 2010 | Washing Machines
NO WATER INTAKE WHILE RINSE OPTION IS ON
It sound like the cold water inlet valve is faulty, the rinse cycle uses only cold water, and the water in the 'wash' cycle is probably hot.You need a new inlet valve, which on your machine is probably a double hot/cold unit.If you can't get a new inlet valve, a handyman/electrician may be able to change the wiring to use the 'hot' inlet valve for cold water which will allow the machine to wash, and rinse, using cold water through the hot valve..Tikka?...Good luck...Nomess
Jun 01, 2010 | LG WFT1071TP Top Load Washer
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
When washing machine goes to rinse cycle, water barely comes in
I am going to guess you run a warm wash, and cold rinse. This sounds like the screen on the cold water inlet is clogged. Shut the water off and remove the hose at the back of the machine. Look in the water inlet and see if the screen is clogged. If so, carefully scrape it as clean as you can. Use a straw and blow into it to help clear it out. Replace the hose and try it. It does not need to be perfectly clean, but at least half way opened will suffice.
Jan 01, 2010 | Kenmore Washing Machines
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
WATER TEMP CONTROL PROBLEM i have no cold cold wash rinse cycle,only hot cold and that rinses in hot
Hi, Sounds like the cold water side of the mixer valve has gone bad or has gotten plugged. Do you have cold water in the wash cycle?
Remove the hoses from the inlet valve and see if there is sand in the screens.
Please let me know if I can assist you further.
Vic
Jun 20, 2009 | Washing Machines
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
Fisher and Paykel GWL11 Top Load Washer Logo
276 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
