Question about Brother IntelliFAX 4100 Laser Fax
Brother4100 intellifax roller
I'm not sure how I would install the roller to my fax machine ? for the past two weeks its make a very bad sound.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
I have just replaced all the toner cartridges in my fax and it did a self clean. The machine was making these noises which sounded like the roller was getting stuck. It would then come up with a paper...
Open control panel on your personal computer where the printer is installed. Click the printer and faxes. Then right click on the icon of your printer and click properties. Then click the maintenance Click the Bottom Plate Cleaning. If the noise is still there after you clean the bottom Plate. Clean the Roller. And look inside your printer if there is something that blocking the roller.
Jun 24, 2011 | Brother IntelliFax-1860C Plain Paper...
I cannot send faxes or make copies with my Brother intellifax 1270e. When the paper gets to the read point sensor it stops and says "press stop button" . The machine will receive fine and print...
Cleaning the Scanner
Before cleaning, unplug the power cord for safety. Clean the white roller and the glass
strip under the roller with isopropyl alcohol on a lint-free cloth. You'll need to lift the
two release levers to release the white roller; be sure to lock them in place when you're
through.
During cleaning, I recommend you unplug the power cord for safety.
Brother fax-back system (USA Only)
Brother Customer Service has installed an easy-to-use fax-back system, so you can get
instant answers to common technical questions and product information for all Brother
products. This system is available 24 hours a day, 7 days a week. You can use the
system to send faxes to any fax machine, not just the one from which you are calling.
If you can't resolve difficulty with your fax machine using this manual, call our
fax-back system, and follow the voice prompts to receive faxed instructions about
using the system, and an index of fax-back subjects.
The Brother fax-back system number has been preprogrammed on One Touch key
Dec 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a blank line running down the left side of all my faxes and copies. I have changed the toner and installed a new drum. Still having the problem.
You most likely have toner on the roller, which should be just above or below the drum, clean this by spraying some window cleaner on a paper towel, or lintless rag, and rubbing the roller clean, make sure to get all foreign particles of roller before closing and trying to print.
Oct 14, 2010 | Brother IntelliFax-2820 Laser Fax
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Hi, I just wanted to know if the intellifax 4100 will print also. I was going to connect to my laptop.
Yes, we used to connect to the fax machine to print via parallel cable, but our new laptop computer does not have a parallel port, so we connect via USB now to use the Brother 4100 Intellifax as a printer. It prints very nicely. We downloaded the driver from BrotherUSA.com
http://www.brother-usa.com/Downloads/
and clicked on Fax Machines, then our Intellifax 4100e, then View Download and selected our operating system and language. Just a tip - When you decompress the download, in the location to decompress to, add a folder to hold the files named Brother4100 or something like that, then when you add the printer, select that folder as your "Have Disk" location. Hope it works well for you.
Jan 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 1270e
Make sure ribbon is installed correctly. Also check inside the tray area to see if the rubber roller and or the rubber separator pad is dislodged. Obviously not worth repairing unless under warranty.
Jul 09, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 4100 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
