Indesit W 123 Front Load Washer
Problem for Indesit W 123 Front Load Washer
WD12 Indesit washer/dryer
By sportsmadsi on Mar 22, 2006
After putting in a wash, the dial continuously span and the light flashed 10 times then paused, 10 times and paused etc.
I cleaned the filter and removed a 5p coin, I have tried resetting to the dot but this has no effect. I have looked at the hot and cold water pipes (These work) I have checked the black outlet pipe from the machine (no blockages).
The dial just keeps spinning.
Any clues as to error code 10?
Same Problem
Apr 14, 2009
-   Anesta1 - just recently had the same problem. Take the top of your washer and you can see the catch - use your finger to prise it open (it doesn't take alot of effort). This should open your day and allow you to change the door handle (which is what I have just done) door handdle part £20~.
DISCONNECT THE UNIT BEFORE TAKING THE TOP OFF!!!!
-   Rogar1471
Aug 28, 2008
-   my indesit fills then drain stright away -   navadah joe
Aug 12, 2008
-   error code 10 showing on my indesit wd 12 washer dryer. it does not fill with water and the programme control clicks round continuousely. I have checked the water supply and checked for blockages, none found. I have even replaced the solenoid valve (cold) and the same error code displays with the programme control still clicks round.-   Stix1711
Jan 20, 2008
-   w130 same problem as above-   washerlee
Best Solution
posted on Apr 16, 2007
Very Helpful)
peatey
Rank: Apprentice
Rating: 100%, 1 votes
this problem could also be a jammed pump
Was this helpful?
Yes
No
Solution #2
posted on Apr 11, 2006
Helpful)
dovi
Rank: Guru
Rating: 88%, 2496 votes
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Timer- If your washing machine fills with water and begins agitating, but the timer won't advance. Then you need to replace the timer.
Water supply problem- If water doesn't enter the machine when you start the process- check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open).
Check that water entrance valve works (it is an electromagnet valve,loocated at the pipe's enterance to the machine).
If it doesn't work, test that it get power. In case it doesn't get power, it seems that the problem is with the timer unit. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!!
Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
Was this helpful?
Yes
No
Solution #3
posted on Jan 28, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my indesit wd12 is not spinning
Solution #4
posted on Oct 07, 2008
Not Rated)
anesta1
Rank: Apprentice
Rating: 0%, 0 votes
My wSHER DRYER WD12 IS WORKING BUT THE PROBLEM I HAVE ISD THE DOCK IS LOCKED COMPLETELY COULD IT BE THE MECHANISM OR ELECTRICAL EVERYTHING ELSE IS OK BUT I CANNOT OPEN THE DOOR TO GET MY WASHING OUT!
Was this helpful?
Yes
No
Popular Solutions for Indesit W 123 Front Load
Questions and Unsolved Problems for Indesit W 123 Front Load
Do you recommend Indesit W 123 Front Load Washer?
Answer
Answer
machine stops at the drain and rinse cycle with 1,3,5 lights flashing
Answer
top load washer will fill and agitate but when it gets to the rinse cycle it just hums..hums on the... (More)
Answer
Every few months my ATF6000ES front loader will not spin at the end of the cycle. It would run for... (More)
Answer
My Indiset W143 washing machine refuses to finish its cycle, it seems to do the wash bit but will... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Indesit W 123 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
