Question about Kenmore 95589 Electric Kitchen Range
Dual cooking zone burner not working
Kenmore 30" radiant self cleaning electric range model 911.95589
The right front element has two cooking zones 9" and 6". The small 6" doesn't work. When it is at that smaller setting, the whole front surface doesn't heat up and stays cool to the touch.
Is this something I can fix myself or am I out of luck.
  • Anonymous Mar 28, 2014
    Is this normal
  • 5,911 Answers
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at repairclinic.com for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
Posted on Sep 09, 2008
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
Dec 19, 2014 | Kenmore Kitchen Ranges
Electrolux burners not working
Hi Amy Goduti - If the oven is working but the cook top is not, the range may possibly be experiencing an issue with a wiring failure or EOC. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the cook top. If it proves to be ineffective, contact a professional to move forward accurately.
Mar 08, 2013 | Electrolux EW30ES65GS 30" Slide-in...
Top is scrached can it be replace
yes $298.00 but you are missing the last letter of your model # denotes the color
Feb 21, 2010 | Frigidaire FEF366EC 30" Freestanding...
Front right side burner does not work.
This is an easy repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct burner out to you right away.
You will be cooking again in no time!
Call us from 7 AM until 9 PM CST. Thanks, Ella
Nov 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Front left element is in run-away mode; it keeps cycling on and off when the knob is in the off position.
The knob (also called thermostatic control) is stuck/broken. The burner is going on and off just as it does when it's in normal use. Just can't turn it off. Will probably need to replace the thermostatic control -- not easily repaired.
Charlie
Aug 23, 2009 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Self cleaning oven directions for mode fed355ccs-b
Here is the directions for cleaning a similiar model:
Frigidaire FED355CCSF
Go to page #19 foor your directions.
If this isn't the right one then look here:
Frigidaire Oven manuals
Hope this helps and please remember to rate this!
Dec 07, 2008 | Frigidaire FEF366EC 30" Freestanding...
Self cleaning oven
http://www.frigidaire.com/support/Result... just need to identify exactly which model you have and download your manual. May your burners be eternally clean Hope this helps :)
Mar 14, 2007 | Frigidaire FEF366EC 30" Freestanding...
Kenmore 95589 Electric Kitchen Range Logo
650 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
