Question about Minolta EP4000/5000 CS/PRO Copier
EP4000 C004A error
We a pretty broke non-profit group and we just bought a used EP4000. It's giving us a "C004A" error message. Is this something that we can fix ourselves? Can we buy parts somewhere?
Any help would be greatly appreciated.
Steve
steve@cannacare.org
  • stevesarich Sep 11, 2008
    I've located the fan. I removed the back cover and it doesn't seem to be spinning when I power up. Is there a fuse or reset somewhere? If I need to replace it, where do I pick up a new fan?
    Thanks for all your help!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Minolta Master
  • 1,362 Answers
C004A Exposure fan problem
Open the back and check the fan that is probably suppose to **** air out of the optics area.
where the light comes on and scans across the glass
Posted on Sep 11, 2008
  • CheckitRight
    CheckitRight Sep 11, 2008
    I beleive the fan is connected to a board not a fuser, check, you may need to replace the board
    try precisionroller.com
    they are very helpful and Most prices are reasonable.
Have a Minolta CSPro 3050 with error code C004A. What does it mean
There is a fan located under the big glass section remove the glass an check the fan clean it or replace it.
Feb 01, 2012 | Minolta Office Equipment & Supplies
C004a code...old unit i use for seniors groups. dont want to spend $$$
Hi this is an issue with the exposure fan as you do not want to spen moeny to fix it unplug the machine take off all the panels side and back use air can and clean all the fans the fan is not turning at the correct speed
Jan 20, 2011 | Minolta EP1083 CS/PRO Copier
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Jul 03, 2009 | Office Equipment & Supplies
Giving code of "C004A". What does that mean?
A C004a code is a error code with a fan in the copier. It is either not working or is making a noise. You may be able to hear the affected fan and try to lubracate it. There is a Trouble reset botton behind the cover of the display contrast knob. Its on the inside front cover above the fixing unit. Try to rest the code there first. Good Luck
May 04, 2009 | Minolta EP4000/5000 CS/PRO Copier
Error code C004A M5 fan does not turn
This motor runs at a reduced speed for part of the copy cycle - just because it bench tests okay does not mean that it is good. The bushings sometimes get clogged with dust, etc. A drop of light lubricating oil on the shafts may do the trick. The fan should spin freely.
The troubleshooting manual is simply telling you how to use the I/O Check feature of the copier to live-test the motor and determine if the problem is with the motor or PWB-A. This is done from the control panel in the service mode. See the "Switches on PWB's" section of the manual.
The problem is likely with the fan rather than PWB-A.
Nov 14, 2008 | Minolta EP4000/5000 CS/PRO Copier
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
EP3050 error code C004A
May 27, 2008 | Office Equipment & Supplies
256 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
