Question about Audiovox VBP5000 Portable Car DVD Player&VCP Mobile Video System Car Video Player
Dvd does not play
Unit powers up dvd begins to spin,spins about 15 seconds then stops screen has dics loading message on screen
    Problem Solver:
  • 6 Answers
You have to change optic pick unit.
Posted on Jul 23, 2007
    President:
  • 3,130 Answers
Have ya tryed to clean the lens yet with a disc lens cleaner?? if this dosent work the best advise would be to contact the manufacter and see what they charge for the fix. Not much you can do with this stuff without specalized equipment
Posted on Apr 02, 2006
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Why my portable dvd playing won't play when i put a dvd dics in?
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Nov 03, 2012 | Televison & Video
No disc spin-up when inserted or when powering up
The problem is in the pladder motor that spins the DVD, the motor needs to be replaced, but the problem is they only sell the laser pickup assembly, which is very expensive.
Mar 13, 2012 | Samsung DVD-V8600 DVD Player/VCR
Unit stops spinning after loading & shows "no disk"
could be down to a dirty lens , faulty lens or faulty dvd player spindle motor.
jon
Aug 05, 2009 | Amphion Mediaworks M-520 Portable DVD...
NEW DVD DRIVE AS MINE DOES NOT WANT TO PLAY NO DVDS NO MORE, IT SPINS THEN STOPS THAN SPINS THEN STOPS THEN SAYS NO DICS!!! CLEANED MAGID EYE BUT STILL DONT WORK
run ur pc in safe mode and insert dvd disc and then use this around 2min and then start ur window normally and ur dvd drive working
May 07, 2009 | Philips LX3900SA System
Screen got really hot and now it won't play DVD's
I was going to see if you DVD player has a reset button on it but it isn't popping up on Audiovox website.
If you open up the player see if there is a reset button on it. Hold it down for about 5 seconds and see if that works.
Unplug power from the unit and remove the battery as well. Put them back in.
Try a different DVD in case its warped or damaged.
If those don't resolve the issue you should take it in and have someone look at it.
Jun 17, 2008 | Audiovox DT102A
My Technics SL-DV290 stereo has stopped playing dvd/cds, it just says 'no read' when it initially scans dvd/cd prior to play Please help!
This means that the unit can tell that a disc is present, but can not read it. Try opening up the top and cleaning the lens using a cotton swab and alcohol. Let us know if that resolves the problem.
Thanks,
Dan
Apr 02, 2008 | Audio Players & Recorders
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Dec 28, 2007 | Sony SLV-D350P DVD Player/VCR
Cant play games or cd's or dvd's
Sounds as though the drive may be failing. If the unit spins and whirs a lot when loading disks, it will most likely need replacing
Jul 24, 2007 | Sony PlayStation 2 (PS2) Console
Audiovox VBP5000 Portable Car DVD Player&VCP Mobile Video System Car Video Player Logo
165 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
