Question about Compaq Presario CQ50-215NR Notebook
Black band down centre of screen - Compaq Presario CQ50-215NR Notebook
  • Compaq Master
  • 4,924 Answers
Try to see if it is not a issue caused by using a wrong resolution ..In this case if you use one with a small size height ..may cause a black band on the bottom ...so ..open the display settings ...and under the resolution ...choose one by one ...untill you get to one which fits your screen and such ..If this seam not to work ... it may be a corrupted driver..In this case download and reinstall the driver for the video card ..This will fix it if there is something wrong with the driver..If after reinstalling the driver and choosing different resolutions will not make it right again ..you should consider the display being permanently damage d ..and look for a replacement for i t..
to check if it is a display damage ...try to hook up the external monitor ...(secondary monitor ..vga out ) ..Just plug another monitor you may have around in the vga port ..and enable it from the driver ..If that black band appears again ..it means there is nothing wrong with the display ..but it something from the video card ..or operation system ..First try to reinstall it ..and than look for video card replacement ..or in case it is a built in video card ..and can not be replaced..and also has no slot for other card to be installed...you may consider to get a external card on fire-wire or usb ..for to be able to use it proper ..(will be tricky to make the wiring for the monitor ..but will work with an external one .
lets hope it is nothing that serious and will work ..
Posted on Dec 04, 2011
SOURCE:
Relisys tv model no rp4207b ru black line down centre
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 25, 2015 | Relisys Televison & Video
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Televison & Video
I have a 2 inch black band which appears intermittently dwon the full height of a 22inch JVC lcd television can anyone explain it for me? thanks
If it is black vertical band from the top all the way down to the bottom of the screen, your LCD panel is going bad and you will see more bands and it will get worst.
Nov 04, 2009 | JVC LT-23S2 23 in. LCD Television
Balck band on the screen when scanning
If black bands are appearing on all documents your scanning then yes you have to get a new scanner. Main board inside of the scanner is going bad and you can't buy spare parts for scanners.
The other thing you can check just to be sure. When the scanner is scanning the light will go all the way to one side and then move all the way to the other side. Look at the light and see if it stays on the whole way when its moving from side to to side, if it does then the main board is bad, if it doesn't then it could be a faulty scanner light and that you maybe able to replace depending on how old the scanner is. Best thing at that point would be to google your scanner and see if that spare lamp is available.
Aug 08, 2009 | Canon Office Equipment & Supplies
Translucent yellow band down centre of recieved picture.
Normal 0 How much memory is installed in your computer? The camera uses quite a bit of your memory to operate properly and would cause the poor video. Could be other
Issues, but worth checking.
Hope this helps. Bud
Jan 18, 2009 | Logitech Webcam
Sky PDS4250 42'' Plasma TV - Black line down centre of screen
not sure if this is the fix or not ...but i was tryin to fix a problem with my tv(not the same as yours)...but in the menu under adanced you can split the screen ....when i do that it puts a blue line down the middle of the screen
Dec 04, 2008 | Protron PLTV-4250 42 in. LCD Television
Black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Funny screen and refusal to start
Sounds like a Video ram or system ram problem which is on the system board. Needs service.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 22, 2008 | Toshiba Satellite A105 Notebook
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Compaq Presario CQ50-215NR Notebook Logo
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
