Question about Lands Phones
Problem with sf-365tp
Have checked all, rang from my mobile and it cut me off after 20 seconds and didnt record my message
  • cw635 Sep 09, 2008
    yes, still have manuel, but dosent state resolving this problem
    seems to have worked, although message has been on for ages and problem has just occured, thanks
    Brigadier General:
  • Lands Phones Master
  • 3,614 Answers
Ok.. first i want to know if you still have a copy of your manual there..?
Posted on Sep 09, 2008
  • 2 more comments
  • micromaster
    micromaster Sep 09, 2008
    The TAM message is an greeting message which plays whenever a call comes in and the machine is in TAM
    Mode. For more information about reception modes, see "Receiving in TAM mode (SF-365TP)" on page 3.6.
    1 Press and hold Greeting until you hear a beep.
    2 Speak into the microphone on the Control Panel within 30cm range from the time you see Record in the display.
    • You can record a message which lasts up to 20 seconds.
    • You are advised to record a message of less than 15 seconds in duration to prevent the incoming faxes from
    malfunctioning due to a long message.
    • Press Stop/Clear or Greeting if you want to stop recording before the time is up.
    • After the message has been recorded, the machine briefly displays the date and time when the message was recorded.
    Then, it displays the elapsed time as the message plays back automatically.
  • micromaster
    Checking your TAM message
    The TAM message plays back when your machine is in TAM Mode and receives a call.
    Press Greeting.
    • The display shows the time when the message was recorded. The display then counts down the seconds as the
    message is playing back.
  • micromaster
    you must record your message within less than 20 sec.
  • micromaster
    hi there,
    cw635:
    kindly please rate my solution as fiXya HERE
    Samsung sf-365tp wont answer incoming
    Thank you.
    Regards,
    micromaster=
Phone beeps every few minutes. Does it need a new battery? Where can it be purchased?
batteries for mobile phones can be obtained from e-bay, battery shops or service dealers
A regular beep on a cordless phone is a report saying that there is a recorded message or some one rang until the recorder cut in then they hung up
you have the battery number so in the search section of e-bay just type in battery and those details and there will pages and some will say fits that phone
Dec 11, 2015 | Siemens Gigaset SL785 Cordless Phone...
Samsung sf-365tp wont answer incoming calls
please reset the phone set to factory settings
Sep 09, 2008 | Samsung Lands Phones
Oven gives err message when set above 275 degrees
Your range has been reset to celsius from fahrenheit. It must be reset to fahrenheit.
Press bake and broil pads simultaneous for approximately 3 to 4 seconds.
When SF comes on, press the broil pad.
You should see the Letter C.
Press again and the letter F will come on.
Press start.
Your range shouldproperly set the temprature now!
May 03, 2012 | GE Profile JTP56 Electric Double Oven
How i can print any file from a pc to sf-360 ( my windose xp )
The SF-360 does not have a printer functionality I'm afraid, only the SF-361P and SF-365TP can be used as printers and have a socket to connect to a computer
It is theoretically possible, if you have a faxmodem in your PC, to send a fax from the computer to the printer, but this is rather complicated and the print quality would be poor (like a fax).
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Samsung SF360 Plain Paper Inkjet Fax
How do i change outgoing answer phone message
Solution for Fax1360, if this does not work please let me know as this process should be the same.
Recording an outgoing message (OGM) on an external TAD 7
Timing is important in recording this message. The message sets up the ways to handle both manual and automatic fax reception.
a Record 5 seconds of silence at the beginning of your message. (This allows your machine time to listen for the fax CNG tones of automatic transmissions before they stop.)
b Limit your speaking to 20 seconds.
c End your 20-second message by giving your Fax Receive Code for people sending manual faxes. For example: 'After the beep, leave a message or send a fax by pressing *5 1 and Start.'
Recommendation: recommend beginning your OGM with an initial 5-second silence because the machine cannot hear fax tones over a resonant or loud voice. You may try omitting this pause, but if your machine has trouble receiving, then you must rerecord the OGM to include it.
Christy
Sep 26, 2010 | Brother Inkjet Fax Machine Fax1460 Plain...
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Error message says
centeral locking switch in frount drivers door faulty
Jul 29, 2009 | 1998 Land Rover Range Rover
Samsung fax machine SF-365TP
Before diagnose the problem please turn off the Machine.
Check all sensor if they have dust then clean it.
Close properly the cover.
Sep 15, 2008 | Samsung Office Equipment & Supplies
No Audio 10 Error
What have you got hooked up? Another CD, tape outs from an amp or a record deck? No audio is a strange message to get, like you say you're using an audio cdr and that's usually what it means. What about if you press record with *no* source connected? Unit should record 20 seconds of silence then cut off.
Jan 20, 2008 | Philips CDR765 2-Disc CD Recorder
Lands Phones Logo
79 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
