Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP Officejet 6110 all-in-one fax/scanner
I have to reprogram the fax machine as I switched from Bell to Rogers. I know the line is good as I tested it with my phone jack and was successful in sending a fax out to a client. I must be missing a step because I cannot receive or send faxes using the line for the fax machine.
Can you help please. I'm losing business!
Maureen
    Novelist:
    Scholar:
  • 111 Answers
Not sure what the problem is exactly. You say that your line is good and you successfully sent a fax using the machine but then you said you can't receive or send...apparently using the phone jack you have available for your machine. It should work using any phone jack you have available in your place.
HP.com has a web page that contains a wide variety of fax troubleshooting steps that may help you. Sorry I can't be more specific, but without knowing more about the problem, this is my best suggestion:
Troubleshooting Fax Issues
Post back your results and good luck.
Posted on Oct 14, 2008
Wont send message. Error no 442
This error indicates that the receiving machine (receiver) cannot receive the fax you just sent. The reasons might be unexpected shutdown of the machine (Receiver's machine) just before it completely received [or partially printed] the file you had sent or power failure during the process.
Another reason is, when we send color fax from Hp machine to another Machine (non-hp), this happens due to incompatibility issue.
Solutions are;
1. Restart both the machine after deleting the recently sent/received fax.
2. Send black and white only, not color.
3. Try again after the phone line seems not much busy which means when there's better transmission capability.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Unable to scan or fax. I have a HP Officejet 6110 all-in-one printer, copyer, scanner and fax machine. I have never used the scanner and the fax simply stopped working after years of service. The printer...
Thanx for contacting in fixya....
u need to uninstall the printer software and then reinstall if this problem persists again format ur system c driver it is the only sure solution
regards
john symester
Nov 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Home phone line and fax on one line
Mine is free from Bellsouth. I do not know about other phone companies.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Will the fax know if it's a phone call or a fax?
Dear sir; I have same question before, finally I found a device from " radio shack" it call phone & fax separater. good luck!
Dec 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 won't receive faxon single line phone with dsl
Have you tried to use the machine on a normal phone line? A dsl line shouldn't be any different as far as fax machines are concerned.
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax machine
First of all, you need to connect a phone line to the printer. use the CD that came with the pirnter, install the fax software and follow the on screen instruction.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax will fax or receive fax
If it is a Officejet 6110 All-In-One first run a fax test:
Press Menu/Setup> Press the right arrow key to locate Tools> Press OK> Now press the right arrow key to locate Run Fax Test> and press Ok.
Check to see what has failed and correct what ever has failed in the fax test.
And follow the below mentioned steps to connect the All-In-One according to your setup:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
FAx Line will not pick up or send faxes on HP 6110 All in One Officejet
it seems like you have lots of services on your line. here are the things that i want you to follow to somehow resolve the issue.
1. Press the setup button on your printer, then use the arrow down button to scroll down and go to ADVANCE FAX SETUP.
2. Press okay on Advance fax setup, then it will give you options.
3. The first option is DISTINCTIVE RINGS, press okay on that.
4. It will give you first option "DISTINCTIVE RING", scroll down and look for "answer on double rings" then press okay. then try letting someone send you a fax.
Note: make sure that your answering machine is using your home telephone line so that it wont affect the faxing functionality.
1. if the issue still not resolve, try to press setup, then go to TOOLS.
2. press okay on TOOLS and it will give you options, scroll down using the arrow down button and look for RUN FAX TEST.
3. Check the result of the test if everything passed!
Let me know if the issue still not resolve so that i can go ahead and give you additional steps.
thank you so much.
adonscott
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
