I have two problems. One I cannot access changing the time etc. That screen will not show when I go through SETUP. How do I change? Secondly, I have a DVD player hooked up to my Olivia TV. How do I get it to play? Do I access a particular channel or what? No mention of how in the Olivia or DVD manuals. I have a Model 232T HDTV
  • chicagoan Sep 12, 2008
    I have a dvd/cd player maker is CLASSIC model mp3
    Master:
  • 726 Answers
From the dvd should be yellow red and white ,,,yellow video other 2 audio from dvd player out to tv input then press av
That screen will not show when I go through setup that might be fault with the tv
Posted on Sep 12, 2008
    Brigadier General:
  • 3,614 Answers
What is the exact model maker of your DVD...? are you using a universal remote or not..?
Posted on Sep 09, 2008
  • 2,336 Answers
You can access the set up mode menu if you have the TV mode.
The DVD should be hook up to the TV using A/V inputs using yellow, red and white cables and select A/V 1 or any other input where the cables are connected to.
  • Jaime Hernandez Sep 12, 2008
    If you are unable to get video when connecting the DVD player using the Yellow, Red and white cables then is more likely that your LCD might be defective. I would suggest to call the manufacturers for additional technical support and if your LCD is less then a year old ask them to fix it under warranty.
    The instructions to set the time and date should be there. Click here to download the user's guide for a 237T HDTV and see if page # 57 will help you. The model number is different, the set up options are the same.
    You can also do a factory default and start with the initial set up again. See Page # 59.
My netbook fell down n when I tried to start it a blue screen with setup utility comes n I tried changing options n restarting n the same screen keeps coming... Plz help..
The problem is the any hardware part is not it its proper position
Avinash it can be hard disk or even the ram
Please first try to open and see all this component are in the proper state and secondly it can also be hard disk failure you have to specify me that if the computer goes in blue screen does the hard disk light is still blinking and if you can go the bios option then its more better
when you power the device then click on the f2 or f1 it will show your bios option then scroll down and you will see hard disk please specify me that its showing anything on the harddisk i mean the vendor name or model no
please reply back
Nov 18, 2012 | Computers & Internet
Cant access bios to change boot order to reuinstall windows 7
Boot the computer and watch the screen. It will tell you what key to hit to get into the Bios or System Setup. You have to hit the key when you see the message or it won't work and you will have to restart.
It also shows you which key to hit to change the Boot Sequence or Boot Order. But you have to hit the key when the message appears on the screen or it won't work and you'll have to reboot. This is a temporary 1 time change for the current boot cycle. When you change it in the Bios or System Setup it's a permanent change.
May 25, 2012 | Computers & Internet
My Laptop only shows ASUS at startup
Corrupted BIOS, nothing to do, change the motherboard :-S
Jan 23, 2012 | Computers & Internet
HI>> This problem started a few days ago. When I turn on the computer, it does not show the logging page, instead a screen comes up saying that REAL TIME CLOCK batteries are low or ONBOARD BATTERY...
Your PC should not crash from this issue. Your PC motherboard has a small (usually watch size) battery on it that provides power for the clock, and basic I/O settings, such as boot options, disk drives etc... The battery is pretty easy to replace, just open the case and you will see the battery held in a little socket. Make sure to turn PC off and properly ground yourself by using a static wrist band or leaning one arm over the power supply while taking the battery out. Take the battery and go to your local RadioShack, The Source, London Drugs etc.. and show them the battery. It should be a pretty common battery such as a CR2032 or CR2025 etc..
Once you replace the battery go into the BIOS by pressing F2, ESC, or DEL (which ever command shows on your screen for Bios Setup, System setup etc).. Change the clock to read the current time and exit, saving changes. You should not get this error for a long time as these batteries last much like a watch would.
If you don't change the battery, it won't crash your PC, but will eventually annoy you enough to replace it :)
Regards, Chris
Jul 12, 2011 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
How do i change the time
The time and date are programmed through system programming. A 4015 phone cannot do this programming. A 4150 phone setup as a subattendant phone with the "attendant setup time/date" class of service option enabled for the 4150's class of service can change the system time and date. This is accessed through the LCD touch screen keys of the 4150. Scroll through the options in the screen until you find set time /date.
Also an attendant console with the "attendant setup time/date" class of service option enabled for its class of service can change the time and date. Press the function button then choose attendant function.
Choose set time. Enter the time in four digits as in 0800 for 8:00. Choose PM if needed. Choose set.
Choose exit to finish.
Dec 13, 2010 | Mitel Superset 4015 Corded Phone
What is standard timings in degees? want to detune engine
hi,might be able to help,firstly you wont be able to change the timing,the timing is preset on the pickup plate and is not adjustable,secondly ,the advance/****** feature of the timing is controlled by the cdi unit and once again not adjustable,the only  way i can think of to detune the bike would be through the carb setup,going to smaller jets etc but if it is injected,then remapping the fuel system would be the other way,hope this helps..cheers
Feb 28, 2010 | 2001 Yamaha XTZ 660
Access BIOS
Oh, you can see it in the splash screen. The screen where the 'Compaq' logo shows up has the keys to what goes where. See the bottom of the screen.
See 'Setup' etc. If it doesn't show up (doesn't in mine, as my monitor starts late), then start it up and then reboot. The monitor doesn't switch off here. So, you can see it.
Dec 12, 2008 | IBM Pentium MMX, 200 MHz (656286U)...
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
Changing the time in the display screen.
USE FUNCTION/MENU BUTTON TO GO TO SYSTEM SETUP AND CHANGE THE DATE AND TIME AS U WANT HAPPY FAXING OMNIPRESENT
May 10, 2007 | Samsung SF-750 Plain Paper Laser Fax
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
