FixYa.com
Tags:
Legacy Audio American Legacy II LA690 Car Audio Amplifier
American legacy II LA690 amp (by 3 users)
posted by shitkicker on Mar 22, 2006
i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever i bridge the amp it shuts off and i don't want it to
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by martiomarty, posted on Jul 20, 2008
i have a 300w clarion maybe 4 months old and it quit on me and has a blue power light on and a red light with a lock symbol the connections and fuses and grounds are good so i dont get it. can anyone help me out?
Comment by Enthusia, posted on Nov 04, 2007
I have a power mixer biamping 16 cha 300W, 2 - 8 ohm speakers, that prematurely shuts off, after 3 minutes of running from the start. After a 10 seconds rest I turned it on again, took only a few seconds running and shuts off again. But when I opened and use an electric fan focused at, where several power transistors 2pcs of BD 241B, and 4 pcs of MJE 15030, 4 pcs of MJE 15031 and 2 pcs of BF 760 and 2 pcs of BF 757 that were closely mounted on the heat sink. it runs perfectly without interruptions, provided the electric fan is running at full speed..
Best Solution
posted on Mar 25, 2006
Helpful (85)
Electro
Rank:Wiz Wiz
Rating: 79%, 103 votes
it's shutting off for a reason. What speakers are you trying to run? Do you know what impedance they are wired for? Where is the gain set?
When bridged that amp is only stable at 4 ohms mono and will/should shut down at impedances lower than that.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 21, 2007
Not Rated (0)
J-Dogg
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
use your amp right or it will blow i had a quad 4 ohm Audiobahn Immortal on a Kicker KX 800.2 and i blew it and thats the last time i wana put 200$ more into my amp now i run 2 12" L7'S dual 4 ohm on my SX1250.1 and thats a rocking system doing around 157db with a caviler in the right incloser
This Problem Also Relates To: Dual 2-Channel Bridgeable MOSFET Amplifier (XPA4100) Car Audio Amplifier Jensen A300HLX Car Audio Amplifier Jensen LXA300 Car Audio Amplifier Jensen LXA400 Car Audio Amplifier Kenwood KAC-5203 Car Audio Amplifier Jensen JPA285 Car Audio Amplifier Kenwood KAC-7202 Car Audio Amplifier
Can you Help with these Car Amplifiers problems?
Car Amplifiers
kenwood kac 818 amp
i have a kenwood 818 amp. one... Answer This...
Car Amplifiers
amp power
my samson S1500 will not power... Answer This...
Car Amplifiers
genon avr1601
Hi gud day i have genov avr1601... Answer This...
Car Amplifiers
i need a code for a universal...
code for a remote control... Answer This...
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
